MicaSense RedEdge-MX Dual
Integrating two five-band cameras, the RedEdge-MX and the new RedEdge-MX Blue, this solution enables the most advanced remote sensing and vegetation research applications.
10-Band Imagery
Integrating two five-band cameras, the RedEdge-MX and the new RedEdge-MX Blue, this solution enables the most advanced remote sensing and vegetation research applications. The performance you rely on from RedEdge-MX with a new coastal blue band, a new green band, and three new bands in the red to red-edge region of the spectrum. Combined with the bands in RedEdge-MX, the 10 bands in the Dual Camera System enable direct comparison between satellite and drone data. Already have a RedEdge-M or RedEdge-MX? Buy the new RedEdge-MX (Upgrade to Dual) kit and get double the spectral resolution.
  • Synchronized capture of all 10 bands for pixel aligned imagery
  • Standard 12 bit TIFF file outputs with embedded metadata for full access to raw data
  • Combined Downwelling Light Sensor and GPS for streamlined integration, accurate ambient light calibration. Only one DLS required.
  • Radiometrically calibrated spectral imagers for precise, repeatable measurements
  • Global shutters on all 10 lenses for distortion-free results on every platform
  • Comes standard with fixed bracket and quick-mount connector for easy integration with DJI drones
  • Compare imagery directly with Landsat and Sentinel satellite data
  • Data is easily processed using Pix4D, Agisoft, and other MicaSense data partners
  • Double the bands for double the analytical capabilities
  • Monitor shallow water environments with the new coastal blue aerosol band
  • Perform detailed analysis on chlorophyll efficiency or the red edge slope with new red, green, and two new red edge bands
Check out the MicaSense RedEdge-MX Dual Here
New Product Multispectral Micasense RedEDGE-M RTF xterarc Commercial UAV/FPV 0 Aug 17, 2018 05:03 AM
Help! Maxx Products (MPI) MX-600, MX-600HP servos SRQFlyer Radios 0 Jan 11, 2017 10:03 PM
Discussion Bell 222 for Mx-400 or Mx-450 ? Helder22 Mini Helis 24 Aug 24, 2007 02:59 PM
Rant MX-400 / MX-450 CCPM driving me nutz.. raynet11 Mini Helis 14 May 21, 2007 09:22 PM
