Binding a FrSky XM+ for XPS X24
Guys, I have an X24 device, and have been using my Horus X12S transmitter and a couple tiny XM+ receivers. Can anyone share what I do to correctly bind an XM+ to my Horus. I've done it before, and sent the entire setup back to the factory, and was told the receiver (single unit) worked very well, and sent it all back. When I got it here at home, it all worked fine as well. After a Summer of none use, it seems I need to rebind the receiver, and cannot figure out what I did, and need to redo. Any help?
Larry |
not sure what the x24 has to do with your bind issue. bind the receivers each separately to your tx and plug them as inputs to the x24.
the receivers and the tx have to be using compatible firmware. theres the EU and the international firmware, just make sure you are using the correct and the latest firmware for everything. |
Thread Tools | |
Similar Threads | |||||
Discussion | Problems binding Frsky xm sbus micro receiver | 2mRedwood | Micro Multirotor Drones | 5 | May 12, 2019 05:45 PM |
Help! | Cant bind T8SG to FrSky XM+ reciever | TBag | Radios | 4 | Apr 04, 2019 03:14 PM |
Discussion | FrSky XM+ Not Binding with Taranis x7 (Eachine x220) | JaperTheCar | Beginner Multirotor Drones | 0 | Aug 24, 2018 05:17 PM |
Help! | New guy, first build, FrSky XM+ bind trouble | three west | Radios | 4 | Sep 14, 2017 07:20 PM |
Discussion | Frsky XM+ will not bind if RSSI pad used? | mactac | FPV Equipment | 2 | Apr 28, 2017 09:21 AM |
