Nov 11, 2019, 07:14 AM
ariaAQ's Avatar
Calculate all your components weight (except the battery), lets say 1600g, your target weight is 2200g, so you need 2200-1600 = 600g battery, try to find the the biggest capacity battery (needs to be near 600g) with minimum 10C rating (I will use 15-20C)
Nov 11, 2019, 04:18 PM
What is the best for FC vibration damping : foam tape or vibration damping board... ?
Nov 11, 2019, 10:41 PM
ariaAQ's Avatar
I use rubber damper for copter 500 size and up, but I designed a different construction, see pics and drawing bellow,
This one was designed for Inspired Flight to use with their Bernoulli 3515-500kv, adjustable size (500-620mm), can take 12-16" props.
Since the motors has a built-in ESC, so no room for ESC.. ..can use external ESC placed under the motor mount.
Nov 12, 2019, 05:09 AM
mlebret's Avatar
Originally Posted by mauribilis
I'm planning to build a new config (but with same electronics excluding esc) with :
- Tarot 650 Iron Man
Good choice... ?
Tarot frame is a poor choice. Look for Daya 680, it is a more stiff frame.
Nov 14, 2019, 08:30 AM
FA3PR9WM79
Oldgazer's Avatar
I have a Tarot 680 Pro Hex and a Tarot 650 Sport quad. Both frames are perfectly fine.
Nov 14, 2019, 02:12 PM
William A's Avatar
Servo tape (thin foam tape).
Nov 17, 2019, 11:25 AM
Cold you advise a length for a case to carry folded tarot 650 with folding props... ?
Nov 17, 2019, 01:04 PM
FA3PR9WM79
Oldgazer's Avatar
Seriously?
Nov 22, 2019, 04:09 AM
Tarot 2814 700KV, or similar SunnySky is suited for "small" 10-11" prop.
Also 3S is pretty old-school.
Since we are talking 550-680 frames, you should strongly consider maxing out prop size. bigger prop => more efficient.
I have Daya550 with SS3508 380KV. Fits 14".. can squeeze 15".
Even better is Martin 330KV. Excellent for 6S
I use 6S for all my builds. Plenty FC/ESC support it. Very popular.
http://www.helipal.com/tarot-mt4008-...tor-330kv.html
2.5KG each. You are thinking overkill now, but more equip later, and besides 4:1 thrust is much more fun to fly
Discussion Best motor gimbal camera around 2.5 kg? Lukas Vorcak Aerial Photography 1 Apr 04, 2016 12:14 PM
Discussion What's the best motor/ESC/batt/prop combo for the NAN Orion? Ollinator44 Electric Competition Soaring-F5J/F5K/ALES/E-Soaring 2 Dec 29, 2015 10:38 AM
Discussion need help for best high power prop motor combo sherlockshah Power Systems 10 Nov 11, 2015 06:35 AM
Discussion Near silent motor/prop combo that can fly up to 1.5 KG aircraft? TheNiceGuy Power Systems 22 Dec 01, 2013 11:16 AM
Discussion which size props and motors should I use for 1.5 kg quad? ali26300 Multirotor Drone Electronics 3 Sep 09, 2012 11:10 PM
