This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Oct 27, 2019, 10:38 PM
old4570's Avatar
Mini-Review
Turnigy Power / Thrust stand
PART 1 ( of many many parts )
At last a motor is here !
Be a budget 2204 / 2300kv 2-3s ( 12A - 120W - 14 pole )
The very first thing I wanted to check was RPM accuracy as I had seen a complaint or two about this !
Now the very first thing anyone has to understand is :
You have to input the correct pole count for your motor !!! or you will get the wrong RPM read out .
This motor is 14 pole ( advertised as ) .
Setting the test stand to 14 pole :
setting motor speed to 10,000rpm as reported by the test stand
My GT power tacho reported some 9200rpm .. ( 3 blade mode as it was a 3 blade prop )
So where is the discrepancy ? With one or the other or in between ?
I would suggest the read outs are close enough to make any data viable and usable .
The prop was not well balanced .
The test stand being metal , means quite a bit of vibration against a hard surface ( table top ) . ( yeah , balance the prop )
So this is all I have done ..
Mounted the motor , connect things up , and do a quick test run checking RPM ..
Next I will have to check that current draw reading .. ( And balance the prop )
AMPs Test :
I just checked , and the AMPs look to be good ..
So it looks like I can trust the current draw reported by the test stand ..
I threw a 4 blade on as it runs much smoother ..
So I can definitely do some RPM / Watt's / @ RPM range / Thrust - tests ....
So I guess I will have to do some thrust accuracy testing now ..
PART 2
Help! Turnigy Thrust Stand unseen Multirotor Drone Power Systems 13 Aug 16, 2016 06:06 PM
Mini-Review Turnigy Thrust Stand V2 - Show & Tell DutchRC Power Systems 0 Feb 04, 2016 06:30 AM
Discussion Turnigy Thrust Stand v1: Which sensor? daneelgiskard Power Systems 2 Oct 24, 2015 10:19 AM
