Oct 23, 2019, 01:46 AM
Question
Do you need to use an optical ignition cutoff?
I just started setting up my X24 and am wondering that since the x24 has an output that is regulated for ignition (5/6v) can I or should I still use my smart fly optical cutoff? I ask because it would eliminate a battery, although i would need to change connectors on the ignition as its a deans and not a jr connector.
I am wondering because on a gas (100c) I have seen interference by not isolating ignitions.
thoughts?
If I use the smartfly cutoff where would I hook it too? a gear/ch5 output? or use the same output that has the 6v output for ignition as that is the set up for it?
thanks,
Oct 25, 2019, 01:17 AM
The X24's BEC takes the place of an optical ignition cutoff and battery.
Oct 25, 2019, 09:11 AM
Discussion What to use for lipo cutoff (not just an alarm)? jevs Semi Trucks and Construction Equipment 1 Dec 29, 2018 01:03 PM
Question Do I need to use a UBEC for my servos if I am already using an SBEC ESC? uninc4life2010 FPV Equipment 4 Jul 25, 2017 08:10 PM
Discussion Optical ignition cutoff setup grosbeak Fuel Plane Talk 1 Jan 05, 2012 10:08 PM
Question Do you really need optical zoom on an AP camera? Hogster Aerial Photography 7 Apr 11, 2005 02:19 PM
