Just messing around with my 3D printer. Having a little fun. I designed this for a Freewing Mirage that I just bought. It will be articulated by 4, 7g 27oz/in servos. It can redirect thrust and also vary the outlet diameter. May even provide some airbrake effect when all four paddles are open all the way. My first try was too heavy. The set with no bolts was 42.8g. With metal bolts and locknuts, it was 51.6g. Add 28g for the four servos and it would have been 79.6g. Too much to add to the tail. Second try came out at 35.3g and I will use nylon bolts and nuts this time. The new set should weigh 67.3g. That's almost the same as taking 2 servos out of the system.
Kip Jackson
Thread Tools |
My inspiration.
KJ |
Kip |
From Schubeler: "Schubeler performance charts coming soon Preliminary (bench test) data from Schubeler: HET 700-68-2250KV - 6S - 125A - 4kg of thrust HET 700-68-2100KV - 6S - 100A - 3.3kg of thrust (also possible with 7S - 4.2kg of thrust)" |
Very cool little project
![]() Good luck ![]() Would love to see a variable pitch EDF impeller |
Thread Tools | |
Similar Threads | |||||
Video | Virtuoso of Thrust: Dual EDF Thrust Vectoring VTOL System | MONOPHAN1 | VTOLs | 35 | Nov 03, 2019 03:43 PM |
Cool | 3D printed Vectored Thrust nozzle unit and EDF housing (new 64mm EDF housing) | Arxangel | Foamy EDFs | 23 | Aug 16, 2019 08:37 AM |
Question | Could I 3D print my own turbine/impeller for my EDF? | realflow100 | Electric Ducted Fan Jet Talk | 33 | Nov 03, 2017 02:55 PM |
EDF Thrust Vectoring - roll your own | gfcermak | Electric Ducted Fan Jet Talk | 19 | Jul 10, 2008 10:53 PM | |
Discussion | My Twinjet with Thrust Vectoring and Thrust Diff. | Pitchspeeder | Pusher Prop Jet Models | 25 | Nov 13, 2007 08:10 PM |
