Oct 20, 2019, 10:45 AM
Mini Q: missing screws on the kit
Hello:
I'm trying to assembly a second unit of this Mini Q model https://hobbyking.com/en_us/diy-rc-4wd.html
But the bag with the general mounting screws is missing. These screws are diameter 1,9mm. length 6 mm. and have a Philips head.
I've been trying to fin them and these are somehow similar https://tiny.cc/6jnuez
I've RMA it to the shop but I'm not confident to have a good answer.
I will appreciate some hint on this, because with these screws, I canít assembly the car.
Regards,
Oct 20, 2019, 11:03 AM
Low budget fun
Beaver_XT's Avatar
You can use M2 6mm but I remember Mini-Q use self tapping so it'll be a bit difference. M2 will work fine, no problem at all.
RMA it anyway, Hobbyking has really good customer service.
Oct 20, 2019, 11:22 AM
Originally Posted by Beaver_XT
You can use M2 6mm but I remember Mini-Q use self-tapping so it'll be a bit difference. M2 will work fine, no problem at all.
As far as this kit hasn't been assembled yet, all holes are smooth holes, without thread on. If I assemble with 2x6mm metric thread, the hole will take it forever. So, I'm not worry if I can't find self-tapping plastic screws except in case of a marginal hole where the internal pressure might open the plastic shell.
I was wondering if the is is a well know multi crew set box within this small sizes like this https://tiny.cc/k0ouez
I've received a good tread mostly.... but not always.
Thanks.
Be good
Question Frsky X-Lite missing long screw Zinc64 Radios 1 Jul 16, 2019 08:38 PM
Discussion Missing Screws for SuperEZ V3 browntdb FMSmodel 1 May 14, 2019 09:33 PM
News SinoHobby Mini-Q 1/28 On-Road Matt Gunn Micro Cars 1 Apr 05, 2018 08:53 AM
Discussion mini/micro servo connector w/set screw on side? rafe_b Electric Plane Talk 2 Feb 03, 2013 09:57 PM
Discussion Picco Z project (No this IS a Q. on mini PLANES) Jaboi Scratchbuilt Indoor and Micro Models 4 May 12, 2007 10:32 AM
