Oct 20, 2019, 08:50 AM
Info on HK60F Rx and TX
Hi has anyone found a way to bind a HK6A V2 to the HK60F Tx please as HK do not make the HK6S Rx. if not is there a compatible Rx to use with the HK60F
Oct 20, 2019, 09:11 AM
An itch?. Scratch build.
eflightray's Avatar
From a rather old advert --
HobbyKing HK6OF Transmitter is a transmitter with a elevon mixing function. It is 2.4 Gig and uses its own binding, it will only bind with the receivers provided. The transmitter has no model memory. The transmitter comes with two receivers and the transmitter and receivers are 6 channel.
You could try the -- Radios forum -- in case someone knows different.
Cool 1.2-1.3Ghz Tx/Rx All infos on one page - updated: 27/10/2013 iacei FPV Talk 5703 Yesterday 02:07 AM
Discussion OSD info on FPV headset vs. Telemetry info on Tx swhoelefp69 FPV Equipment 5 Feb 12, 2016 02:16 PM
Discussion Need info on esc and motor for old Futaba TX & RX TedD60 Power Systems 13 May 15, 2014 07:14 AM
Advise/info on Futaba FP-T4L TX & FP-R4M RX set? Deaks Radios 0 Apr 14, 2005 05:25 PM
