This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Oct 16, 2019, 08:01 AM
Merch's Avatar
Mini-Review
Eachine Mini Mustang P-51D EPP 400mm Wingspan 2.4G 6-Axis Gyro RC Airplane Fixed Wing
Eachine Mini Mustang P-51D EPP 400mm Wingspan 2.4G 6-Axis Gyro RC Airplane Trainer Fixed Wing RTF One Key Return for Beginner
Reviews on hold until i get over the cold plus my wife fell and injured herself badly.
Specification:
Brand: Eachine
Product Name: Mini Mustang P-51D (Wild Horse)
Version: RTF Gyro (whole set to fly with gyroscope)
Material: EPP
Wingspan: 400 mm (15.75 inches)
Length: 317 mm (12.48 inches)
Motor: 10mm coreless motor (hollow cup)
Receiver: 2 in 1 integrated board
Servo: 2g plastic gear *3
Propeller: 13X7
Flying weight: 60g
Recommended battery: 3.7V-360MAH
Package size (length x width x height): 35X35*15.5cm
Flight time: 14mins
Charging time: 2.5 hours
Package included:
1 x Eachine Mini Mustang P-51D EPP 400mm Wingspan 2.4G RC Airplane Fixed Wing RTF Gyro
Oct 16, 2019, 09:53 AM
paultbg's Avatar
Why someone would learn to fly if the plane can fly by itself and even do aerobatics on it's own ? You can leave the plane at fiels to have fun and you can go home. :-)
Also I believe the one key return should be called U turn as doesn't look to have a GPS inside.
All in all another "great airplane" that would perform "perfect" in our UK windy weather, I'm sure of this. Good luck !
Oct 23, 2019, 02:21 AM
Merch's Avatar
Ah the UK weather is always fun to fly in and sometimes flying while puting very little input into it can be something beginners like
Oct 24, 2019, 09:46 AM
Merch's Avatar
It just arrived today when i finish decorating the house will post some pictures then get a review done with many other products.
Oct 29, 2019, 10:17 PM
Merch's Avatar
Updated with some pictures.
Oct 31, 2019, 07:06 AM
"Aircraftus Fragmentum"
kydawg1's Avatar
Merch.... no flight video?
Nov 01, 2019, 09:25 AM
Quad Erat Demonstrandum
scousethief's Avatar
For a micro it isnt too bad, the aileron servo on the bottom is going to be a pita for us grass landers and if your going to use the wheels then you might as well use the correct 4 blade prop and have a spare 2 blade for belly landings/hand launch..... With those minor things out of the way , its actually quite nice , I will be putting D-Day stripes on mine for orientation because micro grey plane and grey sky = Oh Dear ?????
The stock transmitter isnt too bad either and supplying 3 batteries instead of the normal 1 gets an A+
Nov 01, 2019, 11:05 AM
Merch's Avatar
Yeah video coming when the weather permits me
The wheels are not the best they feel as if they will fall off easy and hand throw-belly landing would be best,ow the weather says it's good for tomorrow lets see
Nov 02, 2019, 07:57 AM
Thats what the screws are for m8, the wheels will not budge when the screws are in place.
The elevator can be reversed : Turn on the transmitter , before you throttle up to bind : Lower the elevator stick and keep it there. The TX will beep and the elevator movement will be reversed. This happens for both Rudder and Aileron also.
Nov 07, 2019, 08:31 AM
Merch's Avatar
It's not where you screw the wheels on the wings that are loose m8,on the thin metal rod,cheers for the tip on the transmitter
New Product Volantex V761-1 Firstar EPP Mini 2.4G 4CH 6 Axis Gyro Micro RC Airplane RTF - $52 lmpuIse Micro Ready-to-Fly 90 Nov 10, 2019 08:06 AM
New Product Volantex RC Ranger 600 761-2 2.4G 3CH 600mm Wingspan EPP 6-Axis Gyro Park Flyer RC Ai guyst Micro Ready-to-Fly 1 Jun 12, 2018 11:37 PM
