Oct 13, 2019, 01:59 PM
Cam+ voltage
First build. I have the Heli Nation Talon F7 V2 and the Runcam Split Mini 2.
I'm trying to power the camera via the cam+ pad but it's not putting out enough voltage to power up the camera, if I connect the camera to a regular 5v pad it powers up just fine. Is there a way to select voltage to the cam+ pad or should I just connect to one of the other 5v pads? I was under the impression the cam+ will have better filtering.
Thanks!
Nov 19, 2019, 08:22 PM
Jasen,
Did you solder the jumper on Vbat pads for 5 volts or volt of battery.
Discussion Connect cam and Vtx direct to lipo power or use Voltage Reg? Ari33 FPV Equipment 3 May 21, 2015 04:55 PM
Discussion Immersion RC 5.8GHz 600mW Tx Board Cam Voltage CrazyCooter75 FPV Equipment 0 Aug 04, 2014 08:53 AM
Discussion Micro cam/tx inline voltage regulator wiring Dr. |2udie FPV Talk 7 Jun 09, 2011 03:53 AM
Discussion Easy Convert a KeyChine Cam into RX Voltage guyg Aerial Photography 16 Feb 06, 2010 06:39 PM
