Oct 13, 2019, 01:34 PM
Altis Nano Won't Run As Switch
I can't get my altis nano to operate as a switch in my Radian. I have used it as a recording altimeter and was very happy with it. Now I'd like to use it to practice ALES in my radian. I cannot seem to find a combination of settings where it will turn my motor off.
Usually what happens is: I program the Nano, I plug the nano into the ESC and RX, I power my TX, I power the plane, I give a quick half throttle holding the plane in place, the prop has a 1/4 second burst of energy then coasts to a stop; if I have emergency restart on, I can then run the plane for as long as I want but it will never turn the motor off.
What am I missing?
Oct 13, 2019, 04:21 PM
solastagia
kcaldwel's Avatar
That's how it works. When you are testing your motor with the quick half throttle, and then shutting the throttle off, that is the flight. If you want it to work, just plug the battery in, start the motor and launch the glider.
If you start the motor, you have to unplug the battery to re-set the Altis as a cut-off. Or for that matter as an AMRT start height recorder for F5J.
Kevin
Oct 13, 2019, 04:48 PM
Kevin
I should clarify, I go to half throttle quickly and leave it there. Then it shuts off after 1/4 second with the stick still up.
Oct 13, 2019, 04:58 PM
Looking at the log for one of these tests, you can see that for some reason, it thinks the altitude has been hit almost immediately...0.01 s after the motor event and despite reading a normal altitude of 0.2-0.5 meters...
Description:
Description:
Oct 13, 2019, 05:22 PM
I also just tested the following with the following results:
  • F5J Contest setting (time only, no altitude switch) -> shut off at appropriate time
  • Just a timer setting -> Shut off when expected
  • Just an altitude switch set to 100 ft -> Never turned off...as expected.
  • Altitude switch set to 100 ft and timer set to anything... -> 0.01s flight.
Oct 13, 2019, 05:38 PM
Flashed the ALES firmware and now the timer works...presumably the altitude does as well. But this means I can't select all the training options like restarting flights, F5J altitudes, etc.
Oct 27, 2019, 06:17 PM
It was a firmware bug. They released an update that fixed it.
Help! Help! My PC won't recognize my Taranis Plus as a joystick! Branson25 Radios 0 Jun 15, 2016 08:40 PM
Discussion FLYCOLOR 25amp ESC won`t run motor mookieman Electric Power Cars 7 Jun 07, 2016 09:04 AM
Discussion Emax Motor Won't Won't Start Consistently, But Runs Fine? retrodog Multirotor Drone Talk 3 Feb 29, 2016 04:08 PM
Help! motor won't run hondaboy92hatch High Performance 7 Nov 10, 2015 02:55 PM
Discussion Phoenix won't run on Surface 3 velottatv Simulators 3 Nov 01, 2015 09:40 AM
