Oct 11, 2019, 11:26 AM
Bungee line new idea
New to us anyway. We tried using 2 sticks in an "X" configuration toward the end of the line to raise the pulling point. you lean it a little toward the end stake and it falls away. Worked great on our edf 's to get them up a little higher. I'll try to get a vid, but here is a pic.
Oct 11, 2019, 04:22 PM
Pro Hoarder
turbonut's Avatar
Interesting idea..if it works why not!
Latest blog entry: In flight
Oct 11, 2019, 09:08 PM
Big gov never Works
St. Martin's Avatar
Chris Golds and his flying buddies were launching 1/2A ducted fans 20+ yrs ago using this method. They used an A-frame. A lot of their methods were in Quiet Flyer, years ago.
Oct 12, 2019, 07:37 AM
Larry Dudeck's Avatar
Hello St. Martin...
...1/2a...?
Oct 12, 2019, 08:46 AM
Big gov never Works
St. Martin's Avatar
Hi Larry, yeah..you remember those screaming, smelly little things, we used to turn props with?
Oct 12, 2019, 06:14 PM
jofro
Pointless exercise, great way to hit the "target", just move your release point (hook) on the model further back and you rotate in no time.
I used to launch lot of my early EDF jets in the old 'nicad' days with the model holding up high at shoulder level with the bungee pulling it down, and it still worked well.
These days I use lot easier system, just pull&let go, DIY! (pics)
Oct 12, 2019, 06:31 PM
On some planes, you can't always put the hook where you would like to.
Oct 12, 2019, 09:02 PM
Pro Hoarder
turbonut's Avatar
Wow it took a whole day for Jo to tell you your doing it wrong..He is slacking
Oct 13, 2019, 05:17 AM
Big gov never Works
St. Martin's Avatar
giggle
Oct 13, 2019, 07:14 AM
FLOEY's Avatar
It isn't easy to come up with something new
https://www.youtube.com/results?sear...ngee+launcher+
Take a look through may be something is relevant for You too.
Oct 13, 2019, 09:56 AM
Thanks. Yes, I copied the PVC ones and it works well. Just noticed some of the planes came close to skimming the ground as did my Stinger on first launch so we tried raising the pull point and it helped. I see some trying to get around 15 degree angle as the plane hangs from a string but I have even more angle because I put the hook further back. Still don't get a high AOA. I had to go to full rate on elev also.
Oct 13, 2019, 04:48 PM
Big gov never Works
St. Martin's Avatar
Different designs need varied hook locations and pull ratio. 15deg is a good srting point. But, one only has to look at the forward hook location on an RBC design, to throw a wrench into the thoughts. Too far back, and you can get the dreaded bungee death roll. Using the tube and cotter pin method vs a hook, allows varied locations of attachments. Not easy to move a hook. I have jets that are fine with 3# pull per # of frame. Others needed up to 6#, to avoid striking the ground. Also, nose heavy will make it sag more.
Oct 13, 2019, 06:43 PM
"tube and cotter pin method vs a hook,"
Sounds good. Details?
Oct 13, 2019, 07:38 PM
Big gov never Works
St. Martin's Avatar
Just a brass tube mounted in the fuselage. The cotter pin to the bungee chord lead. Cotter pin inserts in the tube. Positive release. Another plus, no ugly hook to be seen. https://www.rcgroups.com/forums/show...t-Wings-Hunter
Oct 13, 2019, 07:49 PM
i like it, if it works then sweet. id thought about this before, but have just figured il make a jetapault if i need it.
i like the ingenuity
ahhh yes, jofro chiming in with his infinite wisdom as always.
Discussion Very bad lines in FPV feed, any idea why? ronaldpetergreen Multirotor Drone Power Systems 5 Nov 11, 2018 11:34 AM
Discussion Pipes out of fuel tank bung ewibolo Engines 8 Feb 07, 2018 04:57 PM
Discussion Flew between two powers lines today. Had no idea. Mldukes FPV Talk 2 Mar 30, 2016 07:35 PM
Discussion Home Depot Founder Rips Obama A New Bung Real Ira Life, The Universe, and Politics 67 Sep 23, 2010 10:35 AM
Discussion Flight Line / Tool Boxes and cool ideas? Float Flyer Electric Plane Talk 11 Mar 22, 2006 10:56 PM
