Oct 11, 2019, 08:36 AM
Esc
New to electric sailplanes and have a question, my lipo charger charges to 8.4 volts and my ESC won't work unless I discharge to 7.6 volts? It will beep, maybe spin for 2-3 seconds then quit at the 8.4 volts but works fine if discharged to 7.6. Thanks
Oct 11, 2019, 12:16 PM
Crashbound's Avatar
The typical ESC will handle higher voltage than that. A 3s lipo is 11.1v. I'd guess either defective or some timing or startup programming issue.
What kind of esc and what amp rating is it?
Oct 11, 2019, 12:26 PM
rrcdoug's Avatar
I suspect the ESC has been programmed for two cells and not auto. It may also be programmed for NiMh!
Oct 12, 2019, 08:14 AM
I programed for two cells, think I'll reprogram for two and try again. Hate to waist that power on the discharger. You say it should work at 8.4 volts if programed for two cells? It's a Suppo 20 amp ESC w/BEC. Thanks again.
Oct 12, 2019, 10:30 AM
B for Bruce
BMatthews's Avatar
I've got a couple of Suppo ESC's and did not need to program anything. They self detected the number of lipo cells just fine. Perhaps you accidentally set the upper limit to some number of NiMH pack or something odd like that?
Oct 13, 2019, 02:51 PM
DJ Aerotech
f4you's Avatar
Suppo instructions
Check out the attached info, may be helpful
Joe
Oct 14, 2019, 08:08 AM
4. To select, move the throttle stick in off position, between Beeps repeat. Then you
will hear a confirmation sound.
between beeps repeat, as in do that twice? I think not, just off throttle to confirm and exit programing. At least that's what I did and still have to dump from 8.4 to 7.6 volts for it to work. Does work fine at 7.6 volts.
Oct 14, 2019, 02:49 PM
B for Bruce
BMatthews's Avatar
The translation in the instructions is horrible. But it seems like they want you to flick the throttle to low between the first and second repetition during the 0.5 second pause where the comma is in the table? I guess the confirmation tone would indicate that the mode you flicked the stick for is confirmation that it has been selected or in the case of the brake function switched to the other mode.
So after the startup beeps listen for the first single pulse and flick to low throttle and see if you get confirmation tones that it has selected the Lipo mode?
At least that's how I'm reading it. I can see it being something else too. Like listen for the single beep, pause, singal beep THEN flick the stick down before it has a chance to make the first set for the next option? My thinking is that the first beeo set indicates that the acceptance window is open. The second beep set for the option indicates that the acceotance window is closed. Then pause and the next option opens with the first beep set for that option. The occurance of the confirmation tone whatever that might be, would suggest which is correct.
It is interesting to note that it seems like they deliver them in NiMh mode as default. Or this is a very old page of instructions.
Discussion Dear 4in1 BLHELI32 ESC Manufacturers - Please Include ESC Telemetry Pins on ESC's! Nellik Multirotor Drone Power Systems 4 Oct 24, 2017 03:40 PM
Discussion KISS ESC VS BlHELI ESC VS 32BIT ESC Thunderstrike Multirotor Drone Electronics 7 May 09, 2016 07:52 AM
Discussion Identification of RW.RC 30 and 40A ESCs for wii esc flashing tete Multirotor Drone Electronics 1 Jan 02, 2016 12:18 PM
Discussion Why are my ESC's limited to 2-3s instead of 1-10s? Intentional ESC Abuse. nerobro Mini Multirotor Drones 0 Oct 21, 2015 09:32 AM
Discussion Cobra 2204 2300kv motors + 12A ESC + 5045BN = Burned esc? squat Beginner Multirotor Drones 24 Sep 26, 2015 01:02 AM
