This thread is privately moderated by pval3, who may elect to delete unwanted replies.
Oct 09, 2019, 06:09 PM
Trader Rating: 23
ama 1390
pval3's Avatar
$45.00 USD
Buyer pays shipping
For Sale
Mini ifo
Built with servos and detachable rudder for easy transport.
Covered in hot pink ultra light rip stop kite material. Can be easily recovered in pretty much anything you want including saran wrap for ultra light weight running.
2cirus ultra micros included and rigged.
Love these.. built two and never ended up flying this one..
Ready to ship
Box 17x3x29
2 lbs
Oct 09, 2019, 11:11 PM
Trader Rating: 18
No motor?
Oct 09, 2019, 11:43 PM
Trader Rating: 23
ama 1390
pval3's Avatar
the original motor was an IPS GWS motor ..
then a 280 geared brushed motor.. all no longer viable.
Check out the forums for the best option brushless Outrunner motor you want to use and tie wrap to the center post.
Set your CG by sliding your choice of battery, rx esc up and back until it balances.
Oct 10, 2019, 11:21 AM
Trader Rating: 23
ama 1390
pval3's Avatar
The rip stop it is covered in is very high end and pretty much same weight as stock Mylar but not brittle,.
One of two that I built was covered in the yellow version of this stuff and flown every winter for the last 8 years.. same covering, same glue job... never needed to change it before I sold it.
If you remember the old days, the IFO would hit he ground when it was cold and look like a broken auto window.. not with this stuff.
I’ve covered and flown 7 of these between mini, trainer and regular and they all fly amazingly more durable and maneuverable with this stuff. In fact, if you want to go crazy light, you can peel this stuff off with alcohol and apply heavy duty Saran Wrap.with a glue stick. that works the best for the insane weight fanatic but you will have no ✌️... it - just like the Mylar- is much more effected by temp and debris in your flying area.
Wanted IFO or mini IFO DaddyBigas Aircraft - Electric - Airplanes (FS/W) 2 Oct 15, 2019 09:58 AM
For Sale Mini IFO Frame spudvr Aircraft - Electric - Airplanes (FS/W) 4 Oct 14, 2015 04:37 PM
Wanted Ifo or mini ifo wowser Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 13, 2015 06:32 AM
Discussion Mini ifo specs. wowser Scratchbuilt Indoor and Micro Models 0 Oct 12, 2015 09:37 AM
Mini IFO/T-IFO/Mini T-IFO othy Parkflyers 16 Feb 05, 2003 08:53 PM
