This thread is privately moderated by GLSJr, who may elect to delete unwanted replies.
Oct 09, 2019, 02:04 PM
Stuck On You
Well, I went ahead and selected various connectors (Deans, XT60's, etc.) for different applications. Following soldering best practices, I plugged them together male to female. Well, they must have fallen in love, because they could not be unplugged to save my ***! Is there some trick to disconnecting them without ripping your fingernails off? I understand that you don't want them coming apart in the air, but I hate the thought of tearing the connectors all up with pliers and Vice Grips, or prying them apart with a pocket knife (which is a dead short circuit). One thought I have is trying to spray some silicone where they connect. However, it would be difficult to avoid getting it on the terminals. How do you guys handle this problem?
Oct 10, 2019, 01:38 AM
eagle60's Avatar
Next time do not plug completely one into the other, but only half, so you will keep alignment and have after the possibility to tear them apart. For now desolder one pole and use whatever you want to disconnect plugs, then use my suggestion. For your info I prefer bullet connectors and I do not have this type of problem. To avoid short circuit problems I use following cap available in 4, 5.5 and 6 mm size.
Oct 10, 2019, 12:16 PM
Eagle 60,
Thank you for replying to my post. I must admit that I have never seen that connector. It looks like one-half of a bullet connection. Who makes them and what are they called? Thanks again.
Oct 10, 2019, 11:31 PM
eagle60's Avatar
Bullet connectors are of 2 types:
https://hobbyking.com/it_it/4mm-gold...airs-20pc.html
https://hobbyking.com/it_it/polymax-...pairs-set.html
but I prefer the first one.
Colored items are only plastic caps to prevent short circuits; before them I was using a piece of 4 mm plastic (vipla) tube inserted on the male connector. These plastic caps are made by a friend of mine, but if you look for them in internet you should be able to find them (maybe sebart).
Help! Ezuhf Jr module on Taranis stuck on 8ch? Cody WIlson FPV Equipment 2 Sep 01, 2018 04:13 PM
Discussion Stuck on setting up racing quad on Spektrum DX6e zanemoseley Radios 12 Sep 07, 2017 08:38 PM
Discussion Naze32 rev5 stuck on rebooting Dttocs Multirotor Drone Electronics 1 Nov 27, 2015 04:53 PM
Discussion Hubsan X4 Motor Stuck On lakario Beginner Multirotor Drones 7 Sep 15, 2015 07:53 AM
