This thread is privately moderated by flashted, who may elect to delete unwanted replies.
Oct 09, 2019, 10:23 AM
Trader Rating: 33
"Come and take it B'yatch"
flashted's Avatar
$30.00 USD
Seller Pays Shipping
Sold
4 cobra c-2204/32 brushless , 1960 kv
4 COBRA C-2204/32 BRUSHLESS MOTOR, KV=1960 1 of them NIB
These are the OLD STYLE with seperate propshafts.
3 Flown on a quad maybe 10 times, 1 is new, and never flown.
Would make great plane motors, or great for a quad if you don't care about seperate propshafts.
$30 shipped Paypal ConUS
Stator Diameter 22.0 mm (0.866 in)
Stator Thickness 4.0 mm (0.157 in)
Number of Stator Slots 12
Number of Magnet Poles 14
Motor Wind 32 Turn Delta
Motor Kv Value 1960 RPM per Volt
No Load Current (Io) 0.58 Amps @ 8 Volts
Motor Resistance (Rm) per Phase 0.153 Ohms
Motor Resistance (Rm) Phase to Phase 0.102 Ohms
Maximum Continuous Current 12 Amps
Max Continuous Power (2-cell Li-Po) 90 Watts
Max Continuous Power (3-cell Li-Po) 130 Watts
Motor Weight 22.5 grams (0.79 oz.)
Outside Diameter 27.0 mm (1.063 in.)
Shaft Diameter 3.00 mm (0.118 in.)
Motor Body Length 14.2 mm (0.559 in.)
Overall Shaft Length 21.8 mm (0.858 in.)
Motor Timing 5-10 degrees
PWM Frequency 8 KHz
Oct 10, 2019, 03:01 PM
Trader Rating: 25
From The Lab
Hi - A little more detail please. What is the difference between 'old' and 'new'? Do these come with prop adapters? Any other accessories? Did you attach connectors?
thanks
Steve
Oct 10, 2019, 06:29 PM
Trader Rating: 33
flashted's Avatar
Hello, yes they have prop adapters, they also have bullet connectors attached. I will post some more pics.
Oct 10, 2019, 06:39 PM
Trader Rating: 33
flashted's Avatar
Here is a photo. These are kickin motors, and in the early days of quads they were sought after. Then cobra integrated the shaft with the housing, and then everybody had to have the new version. Would make excellent plane motors. I'm giving them away basically. They were $25 each new. can't beat 30 bucks.
I may keep them for future smaller wing projects.
Also, one has the tabs removed as I had in in a plane, but I did not fly, nor power it up.
Oct 11, 2019, 08:40 AM
Trader Rating: 25
From The Lab
Hi I will take these. Please send paypal info.
Steve
Oct 11, 2019, 08:21 PM
Trader Rating: 33
flashted's Avatar
I PMed you, but your inbox is full, and not accepting, you have to delete some messages.
Leave a message here when you clear it, and I'll get the info to you.
Thnx
Ted
Oct 11, 2019, 08:27 PM
Trader Rating: 25
From The Lab
Sorry about that. There is now room for additional messages.
For Sale Cobra C-2204/32 Brushless Motor, Kv=1960 Bionic420 Aircraft - Electric - Multirotor (FS/W) 0 Jul 02, 2015 08:22 AM
Sold (5) Brand new Cobra 2204/32 1960 Kv brushless motors joshuajcrouch Aircraft - Electric - Multirotor (FS/W) 3 Mar 15, 2015 12:50 AM
Found WANT Cobra 2204/32 1960 kv motor x 4 Derek_S Aircraft - Electric - Multirotor (FS/W) 1 Oct 21, 2014 07:11 AM
News The Cobra 2204/32 Kv=1960 Brushless Multirotor Motor is in stock! RCGroups Update Mini Multirotor Drones 2 Jul 12, 2014 10:40 AM
Found NEED a Cobra 2204/32 1960 KV Derek_S Aircraft - Electric - Multirotor (FS/W) 6 Feb 25, 2014 09:38 AM
