Oct 25, 2019, 05:35 PM
0800howsmyflying
Captan Crash's Avatar
Originally Posted by Vantasstic
To late for me to get the discount. I'll just wait for flight reports. I have enough planes already...but that's never stopped me from adding more to the hangar.
Ha ha......That is so me
Oct 25, 2019, 09:07 PM
I just ordered the kit version! I have a spare Nano Goblin motor and ESC as well as a spare F411wing and gps for iNav.. lets see how this thing goes!
Oct 25, 2019, 11:59 PM
mutski
Originally Posted by Xedos9er
Very nice review, thanks for posting!
I have looked all over creation for a ZOHD or Sunnysky 1406 2600kv motor, no luck. They must have made it special for the Sub-250 Dart. So I guess I'm doing the Speedx GR1408 3500kv, which is as close as I can find to the Nano Goblin's Cobra motor, which remains out of stock.
Oct 26, 2019, 09:24 AM
Aka: Tom Jenkins
ApexAero's Avatar
https://pyrodrone.com/collections/mo...-series-2522kv
These are super lightweight, I've had great success on the original dart. Sure a tad larger diameter but the efficiency is worth it! I used a apc 5.25x4.75 on 3s and 4s.
another option, https://pyrodrone.com/collections/mo...rushless-motor
Oct 26, 2019, 01:36 PM
mutski
The Hyperlite looks heavy at 20 gms, but the Emax looks like it's in the ball park, and I've had very good luck with Emax motors. I might just order one of those. Thanks!
Edit: I'm a little confused with the Emax. The specs say 4-5S but the test data for the 3600kv model are at 12.6v. I guess it must work with 3S, wonder how it does with 2S. Bigger props?
Edit: Here is the answer from GetFPV:
If that stator size and kV is what you're looking for it wont be a problem
They say 4-5S because it's made for 3inch drones
Edit: However, I see the Emax motor will require a prop adapter.
Here is another option
https://www.racedayquads.com/product...xoCckcQAvD_BwE
Oct 26, 2019, 11:29 PM
I'm considering the Emax RS1606 with 4000KV ... works fine on 3 bladed 4" props but I will try the delivery setup first.
Oct 27, 2019, 12:52 AM
aby28's Avatar
Is there any different with the "/ \ " or "\ /" on the vertical stabiliser? As in flight characteristics.
Oct 27, 2019, 05:35 AM
Anybody know when the Zohd 370mm is coming out?
Oct 27, 2019, 06:53 AM
Just another option...
R1106 5500kv and 4x2.5 2 blade on 2S looks like it work well, and would save several grams on the motor.
Oct 28, 2019, 12:19 AM
fly by night
BCSaltchucker's Avatar
I have the same. might do the kit also, but with several mods to get it lighter than the ZOHD setup
Oct 28, 2019, 02:01 AM
Have a great museum day! TB54L
ralfrcgroups's Avatar
Never heard about such a thing....
Oct 28, 2019, 09:42 AM
Anyone else got Backorder notice ??
The same with Nano Talon Evo PNP: expectes shipping date 20-11-2019. ???
Wysłane z mojego SM-A520F przy użyciu Tapatalka
Oct 28, 2019, 11:13 AM
Motor Selection for 2s
I just received my kit from BG today (placed order Oct 10) so now need to decide what to go with for the motor. I'm planning on primarily flying 2s 18650 and am trying to decide between something similar to the stock motor (1406-2600KV ) or something similar to the Strix Nano Goblin stock motor (1407 3500KV). I may wait and see how people make out with the stock motor before I order anything but the three motors I'm looking at are:
I realize that the last one is a higher KV than the stock 1406 motor but not sure if that will be an issue or not. I have the Racestar BR1407 on a foam board 75% FT Goblin and it will fly OK on 2s 18650 but is a bit sluggish - possibly due to the fairly draggy airframe. It flies great on a 850-1000mAh 3s lipo but the flight times are much lower than on the 2s 18650. Even on the 2s 18650, I am only getting about half the flight time my buddies get on their Nano Goblins using the same batteries. Guess there'll be some good discussions on the motor options so will be interesting to hear what people suggest and what they report with the stock motor.
I want/need to keep it under 250g so I don't have to worry about any Transport Canada regulations so will probably have to be very careful on my components. This is partly why I went with the Kit as the ESC and servos that come in the PNP version seem a bit overkill. On my other sub-250g planes I use a 15-16A ESC without any issues which isn't surprising given what they draw on 2s (under 3A most of the time).
Looking forward to hearing and seeing how this thing flies!
Oct 29, 2019, 02:19 AM
You could probably save about 20g just on servos, motor and esc alone
Oct 29, 2019, 10:37 AM
fly by night
since this plane is roughly similar to the nanogoblin, which comes designed around its 1407 3500kv Cobra motor, those motors in the 3500kv range might actually be a better choice for many builds, especially if you wish to run an 18650 2S pack and stay under 250g. And folks use the nanogoblin motor with 3S too. But then prop choice can account for some of the difference in kv. Prop weight worth considering though
New Product NEW ZOHD PLANE (Official): ZOHD Dart XL “Extreme” SonicModell FPV Aircraft 3203 Today 02:20 PM
New Product NEW ZOHD PLANE (Official): ZOHD Talon GT “Rebel” SonicModell Product Announcements 420 Feb 20, 2020 02:15 PM
New Product ZOHD Nano Talon 860mm, ZOHD Orbit Wing & ZOHD Dart Sweepforward Wing 635mm D Gains FPV Aircraft 242 Aug 16, 2019 02:06 AM
Discussion ZOHD New Product - ZOHD Talon GT Rebel QIU FPV Aircraft 1 Mar 14, 2019 09:36 PM
Discussion ZOHD New Product Is Coming Soon GeekBuying Geekbuying.com 2 Mar 13, 2019 10:36 AM
