New Product
New ZOHD Dart250G 570mm Wingspan Sub-250 grams Sweep Forward Wing AIO EPP FPV RC Airp
https://www.banggood.com/custlink/vKvD0WTwI7
Zohd have a new product coming i know what it is but cannot post details just yet............Looks really nice though
ZOHD Dart250G 570mm Wingspan Sub-250 grams Sweep Forward Wing AIO EPP FPV RC Airplane KIT/PNP W/FPV Ready Version Using manufacturer's default configuration and the recommended FPV gear, it is 100% under 250 grams. To the untrained eye, she will look like a harmless toy but, -we and you know- this is a super capable FPV ship that will even let you do long range like the bigger sisters. Being so light, it’s a blessing for beginners since they will find that is really hard to break it. Also, coupled with NEW Kopilot Lite and the VC400 camera, you will get a ready to go FPV system, solder and hassle free. Now you can enjoy more than 30 minutes FPV action (with a 18650 2S1P 3500mAh) or a super thrilling proximity mission (on 3S setup), everything under 250 grams. Since the wingspan is only 570mm, you don’t even need to think about the portability, this thing is bicycle-ready! Forget about those sketchy DIY projects, and spend your time flying a fantastic wing that will perform like a much bigger plane, without the worries of being pointed as a criminal. Description of Dart 250G: Brand Name: ZOHD KIT Item Name: Dart 250G Material: High-Quality EPP Wingspan: 570mm (22.44'') Length: 379mm (14.92in'') Recommanded Devices (not included in KIT version) Motor: 1406-2600KV ESC: 30A w/5V 2A BEC Click Here Servos: 9g Click Here Propeller: 2 blade 5x5 Click Here 3 blade 3x5x3 Click Here Recommended Battery: (not included in any version) Lipo 2S 3S 900-1500mAh Click Here Li-Ion 18650 2S1P 3500mAh Features: 1. AUW is less than 250g, ideal to comply with Sub250g regulations 2. Durable EPP material, built-in CF spar for enhancement, crash resistant 3. Being light-weight will be safe to fly anywhere, anytime. You’re avoiding the hassle of an FPV registration 4. Glue-free assembly, the main wing and tails come with pre-applied adhesive tape, just peel it off and install them 5. Large battery bay for extended flight time 6. Nose camera bay compatible with all FPV and AIO cameras in the market 7. Cover for the fuselage bottom, super durable, protecting the fuselage bottom from scratches 8. Servo arms are well protected by an EPP hump 9. Built-in CF rod in the ailerons will give precision and sharp action to your inputs 10. Dedicated equipment bay for Flight Controller and GPS 11. Main wing leading edge cover for those unexpected impacts 12. Textured areas on both side of the fuselage, for more secure hand launch grip 13. Optimized air-cooling design will keep your gear safe from overheating Specifications of ZOHD VC400 PIGGYBACK AIO NTSC FPV Camera w/ OSD 400mW 5.8G 40CH VTX 600TVL 120 FOV ultra-light Racing Camera: 1. Input voltage: 7-28V 2. Frequency band: 5.8GHZ 3. Video format: NTSC 4. Camera resolution: 600TVL 5. Antenna connector: Clover / Dipole 6. Field of View: 120 degrees 7. Size: 24*15*10mm 8. Weight: 8g 9. Output power: 0.1mW / 25mW / 200mW / 400mW 10. Operating current: 90mA (0.1mW) 150mA (25mW) 270mA (200mW) 360mA (400mW) Features: 1. 3-in-1 AIO integrated design, with camera, VTx and antenna, ultra-light weight and small size, best solution for light-weight airplanes. 2. With OSD to show Power-on time and Input Voltage, so you can know how long you can keep flying. 3. Default JST plug and up to 25cm power cable, longer enough for most small size airplanes. 4. Up to 2.5km video transmission range on 400mW. 5. Wide voltage input from 7-28V, safe for all kinds of battery or BEC input. 6. With customized strap to hold the camera and EVA foam for anti-vibration. 7. Switchable between 0.1mW / 25mW / 200mW / 400mW. 8. Optional Clover / Dipole antenna for different airframes and flight mode (for straight line flights or flying around). 9. 5.8Ghz VTx with 40 racing channels. 10. Allows you to display customized Call Signs. 11. Power cable were soldering and fixed by silica glue, solid even in a crash. Specifications of ZOHD Kopilot Lite Autopilot System Flight Controller with GPS Module Return Home Stabilization Gyro for RC Airplanes Fixed Wing FPV Model 1. Supported planes: T-Tail, V-tail, Flying Wing / d elta Wing. 2. Supported Receiver: PWM, PPM, S-Bus. 3. Supported mode: Home (RTH), Fence (RAD), Stabilization modes. 4. Servo connector: 4 connectors 5. Operating Temperature: -10℃ - 50℃ 6. Weight: 8g. Features: 1. Easy Installation, minimal wiring. Super easy setup. 2. Powerful stabilization and RTH algorithm. 3. Return to Home (RTH) Fence (RAD) and Stabilization modes on a 3-position switch. 4. Supports T-Tail, V-tail and Flying Wing / d elta configurations. 5. Mini-size GPS unit for ultra-light setups. 6. Fast SAT lock. 7. Adjustment board removable for a light-weight setup. 8. Launch assistant and motor blocking for no SAT fix. 9. AIL, ELE, THR, RUD + AUX to control your servos. Landing gear and flaps go straight to RX. 10. Computer-free programming. 11. Easy to transfer between planes 12. Completely transparent. Switch it off and use it as a mixing board only. User manual : click here Introduce about FPV READY version : Dart 250G plane PNP with ZOHD Kopilot Lite Flight Controller and ZOHD VC400 All-in-One Video Camera. Package Included KIT Includes: 1 x Dart 250G plane KIT with EPP foam and all hardware. PNP Includes: 1 x Dart 250G plane PNP with pre-installed motor, esc, servos, propeller, hardware. FPV Version Includes: 1 x Dart 250G plane PNP with pre-installed motor, esc, servos, propeller, hardware + ZOHD Kopilot Lite + ZOHD VC400 All-in-One Video Camera Combo VC400 CAMERA Package 1 x VC400 AIO Camera with lens cover 1 x Manual 1 x Customized strap 2 x EVA anti-vibration foam ZOHD Kopilot Lite Package 1 x Kopilot Lite main board 2 x Mounting support 1 x GPS 1 x Adjustment board 1 x Double side tape 1 x Screw driver |
Mix between Dart XL and Talon GT with a more aerodynamic nose. I'm digging that alot!! Would be perfect to test out the Foxeer Mix 2 thats on the way
It's a beauty ,
My spotter uses Foxeer , good cams he loves them. I will post the other other details as soon as I get the OK. I'm hoping this one will slide nicely in with the acro fans |
Seems videos are up already. Looks a bit wobbly in the videos:
This one is 570mm and uses a 2 or 3S setup. I doubt it would take much to upgrade to 4S and create a small FPV Acro version or something for close proximity racing. I am pushing them for more video and more information regarding using more standard Betaflight/Inav components.
Remains to be seen how heavy it REALLY is. As China is known to lie about this over and again. To my eye it looks a little busy with extraneous stuff that only adds unnecessary weight and drag. 9g servos is definitely overkill and heavy!
Keep in mind it is competing against the Nanogoblin which comes in more like 225g with a basic FPV system and lipo, and 245g with full on inav, gps, Runcam Split and 3500mah 2S pack on her. But .. the price seems right. And I am delighted to see a more direct competitor to the expensive but ingeniously engineered Nanogoblin that RMRC refuses to restock! The kit version might be the better choice for someone wanting to stay under 250g with all the features, put on 5g servos, a 1407 3500kv motor, 4.1 apc prop, opto ESC and an F411w w HGLRC gps, Crossfire mini, some 800mW vtx, 20amp 3500 li ion cells 2S pack, foxeer predator ... and perhaps an Insta360Go! |
The nano goblin is also a strix product meaning its expensive and nearly impossible to actually buy becuase it'll be sold out until dinosaurs re-populate the Earth.
This definitely seems like a great alternative even if it makes some tradeoffs. |
It will be interesting to see what its actual dry weight is. To get an idea of the margin we have for equipment, while still keeping it sub250g.
Would an 1806 motor be suitable for this? I'm not worried about the <250g weight limit.
What would be efficient cruising speed ? I love my z-84 but it gets a little boring at 40-45 km/h. I could transplant everything, maybe apart from f405 wing ( f411 wing instead ) and 9g servos ( 5g should do ). And smaller motor. 2205 2300kv now in z-84 spinning 6x4,5 prop, 3S1P lg gh2 3500mah. Price looks right. [emoji106]
Wysłane z mojego SM-A520F przy użyciu Tapatalka |
Thread Tools | |
Similar Threads | |||||
New Product | NEW ZOHD PLANE (Official): ZOHD Dart XL “Extreme” | SonicModell | FPV Aircraft | 3437 | Apr 13, 2024 04:48 PM |
New Product | NEW ZOHD PLANE (Official): ZOHD Talon GT “Rebel” | SonicModell | Product Announcements | 736 | Jan 26, 2024 12:32 AM |
New Product | ZOHD Nano Talon 860mm, ZOHD Orbit Wing & ZOHD Dart Sweepforward Wing 635mm | D Gains | FPV Aircraft | 249 | Feb 12, 2021 05:58 AM |
Discussion | ZOHD New Product - ZOHD Talon GT Rebel | QIU | FPV Aircraft | 1 | Mar 14, 2019 09:36 PM |
Discussion | ZOHD New Product Is Coming Soon | GeekBuying | Vendor Talk | 2 | Mar 13, 2019 10:36 AM |
