Jul 16, 2020, 12:34 PM
Yes, I think I'll do so, Fuzz.
I added planking on the top of the fuselage and sanded it all down. Still a lot of details to do, but good for some outside shots.
Jul 16, 2020, 03:39 PM
Merlin impersonator
balticS2's Avatar
Very attractive Ronald. What are you planning to cover with?
All the best
Alec
Jul 17, 2020, 05:49 AM
Thanks, Alec.
Covering depends a bit on the paint scheme and I'm undecided about that.
I wanted to use silver heat shrink film for a military scheme. But now I thought of a civilian scheme, probably a racer? Those often don't have a metallic base color.
I have tissue and Koverall available, as well as the film. I prefer the look and feel of tissue or Koverall but painting a metallic base color isn't easy.
Jul 17, 2020, 10:47 AM
Big gov never Works
St. Martin's Avatar
Hi Ronald, that looks like a Mustang! Have you tried poly span?
Fuzz
Jul 19, 2020, 09:39 AM
I read a lot about polyspan on rcgroups but couldn't find a source in Germany up to now.
At the moment I'm leaning towards using some heavier tissue.
Jul 20, 2020, 01:44 AM
So I'M meant to be in control?
Colonel Blink's Avatar
Look for 'polyester tissue'.....Mike at Free Flight Supplies www.freeflightsupplies.co.uk sells it.
Jul 20, 2020, 05:37 AM
Big gov never Works
St. Martin's Avatar
Ronald, Poly Span(or FAI polyester tissue) would be perfect for this size frame. Be sure to get the real thing. There are some heavier stuff being sold in large quantities, that do not have a very smooth good side. The real stuff, is 20"W x 12"L. Grain running the length of the roll. An 18" chord is about max, leaving enough for handling.
Fuzz
Jul 26, 2020, 04:39 PM
Thanks for the hints! I think I found the correct stuff on German supplier's sites.
But I have to admit, I still used the silver heat shrink film from Hobbyking.
I will do a paint scheme with a metallic base color, so it's much easier to use the silver film than to paint the whole plane.
Vertical tail was the first to get started.
Jul 26, 2020, 05:08 PM
Big gov never Works
St. Martin's Avatar
Thats understandable, Ronald. I have used silver or alum iron on as a base also. Makes for nice wear and tear look after painting.
Jul 28, 2020, 03:52 PM
The wing is done, took me the whole evening
Jul 28, 2020, 04:18 PM
Big gov never Works
St. Martin's Avatar
smoooth...looks sleek!
Jul 29, 2020, 09:06 AM
Still the "Pro"-crastinator...
Steve85's Avatar
Beautiful workmanship. You sir, are a craftsman!
Steve
Jul 29, 2020, 06:00 PM
Merlin impersonator
balticS2's Avatar
Looks pretty good for an evening's work to me
Jul 30, 2020, 04:37 AM
Looking great! What's the airframe weight at the moment?
Jul 30, 2020, 11:39 AM
Hey guys, you make me blush
The weight right now including a 3s2200 lipo is 1130g, or 40oz, or 2.5lbs.
I'm still missing a canopy and some detailing. I think that's a good weight so far. The E-Flite P-51 1.2m is just 4 inches bigger but weighs 1500g.
Discussion ‘E-flite’ P-51D Mustang, 44” Span Z-foam, Flaps & Retracts INSTALLED Plane Chaos Electric Warbirds 4679 Oct 18, 2020 09:02 PM
Build Log Earl Stahl Interstate Cadet for YOBBO (1941) - FLYING PHOTOS ADDED! Sundancer Vintage & Old-Timer Designs 69 Apr 28, 2016 12:35 PM
Himax + Earl Stahl P-40 = WOW!! JIMA Scale Kit/Scratch Built 13 Jul 18, 2004 10:11 PM
Earl Stahl P-40 conversion JIMA Scale Kit/Scratch Built 386 Feb 22, 2004 02:54 PM
My Earl Stahl P-40 Conversion JIMA Parkflyers 4 Dec 01, 2003 10:00 AM
