Oct 08, 2019, 03:22 AM
alex_nikiforov's Avatar
Eachine Wizard X140 140mm 3 Inch 3-4S RC FPV Racing Drone PNP Betaflight F4 OSD
Eachine Wizard X140 140mm 3 Inch 3-4S RC FPV Racing Drone PNP Betaflight F4 OSD FOXEER Cam 25~300mW VTX
Note: The different between X140 and X140HV Racing Drone is the motor. The X140 with 3850KV 2-4S . The X140HV with 2500KV 2-6S.
Specification
X140HV Frame Kit
Wheelbase: 140mm
Floor thickness: 3mm
Upper plate thickness: 1.5mm
Side panel thickness: 1.0mm
CNC Aviation Grade 6065 Custom Aluminum Column
1507/3850KV Brushless Motor
KV: 3850kv
Voltage: 2-4s
Weight: 17.7g (including line)
Output shaft length: 14mm
Maximum pulling force: single 740g (6S/3056 three-leaf paddle)
Maximum power: 480w
Number of slots: 9n12p
Mounting hole spacing: 12*12mm
Mounting hole specification: m2
Bearing: nsk
N52 NdFeB magnet
Recommended paddle: 3 inches
20A Brushless ESC
Continuous current: 20A
Peak current: 25A (10s)
Bec output: NO
Input voltage: 2 ~ 6 s
Main control chip: 48mhz efm8bb2
Firmware upgrade: support dshot600 /blheli _ S/Oneshot125
MOS: 3*3
MOS model: pe632ba 30v53a
Betaflight F4 Flight Controller
Main control chip: stm32f411
IMU: mpu6000 6-axis sensor
BEC: 5v/1a
Integrated OSD
PPM/DSM/IBUS/UAR sharing: UART1-RX
Installation size: 20*20
Weight: 3.0g
Support firmware: betaflight/cleanflight/inav
Support for programmable LED Sprit
Reserve buzzer interface
FOXEER Arrow MICRO PRO 1.8mm Camera
Image sensor: 1/3" Sony Super Had II CCD + NextChip 2040 DSP
Pixel: PAL: 976 (H) x 494 (V); NTSC: 768 (H) 494 (V)
TV system: PAL
Resolution: 600TVL (color) 650TVL (black and white)
Synchronization: internal
Minimum illumination: 0.01lux
WDR: Support
OSD programming board: support
White point repair: support
DNR: 2D DNR
Camera title: support
Image adjustment: support
OSD: Edit Name, Power, Flight Time
Input power: 5-40V
Storage temperature: -40 C~60 C
Working temperature: -10C~50C
Power consumption: 70ma
Low pressure alarm: support
Default mode: def, vivative, sunny, cloudy, led tr, usr1
Size: 18.5*19mm (without bracket)
Weight: 5.3g (without bracket)
XF5805 /5.8G 40CH 25/100/200/300mw Switchable VTX
Support TBS SmartAudio
Transmitting power: 25/100/200/300mw adjustable in three steps
Frequency points: 40ch
Video format: full NTSC / PAL format
Input voltage: 7V ~ 26V
Power consumption: +12V/600MW, 260mah
Size: 25 20 4mm
Weight: ≤ 3.2g (except antenna)
With copper tube mini antenna (ipex interface)
Tips: Before powering up, you must first install the antenna to avoid the possibility of burning the tuner.
Multi functional taillight module
Working voltage: 5v
Integrated programmable taillight / bb ring / light strip drive
RGB full color highlight WS2812b lamp beads *2
Integrated 80dBi buzzer
Integrated photon emission line driver
Weight: 3.5g
T3056c Propeller
Material: Imported pc
Installation aperture: 5MM
Center thickness: 6mm
Weight: 2.5g / only
Quantity: 4 pairs (8 pieces)
Color: transparent purple * 2 Pairs / transparent * 2 Pairs
Atmosphere light strip
Feature: Low power consumption, no heat, no impact on flight time.Only 10% of the power consumption of traditional LEDs. Beautiful, soft, not dazzling.Lines can be bended, folded and sheared at will. The installation is flexible and convenient for you to play freely,Long life
Recommended power supply
Recommended voltage: 3-6S
Recommended capacity: 450-750mah
Weight Drone weight: 150g
Package Included:
1 x X140 Frame Kit
1 x Atmosphere light strip
4 x 1507/3850KV Brushless Motor
1 x 4 In 1 20A Brushless ESC
1 x Betaflight F4 Flight Controller
1 x FOXEER Arrow MICRO PRO Camera
1 x XF5805 /5.8G 40CH 25/100/200/300mw Switchable VTX
1 x Multi functional taillight module
8 x T3056c Propeller (transparent purple * 2 Pairs / transparent * 2 Pairs)
1 x Battery board set ( 2mm battery protection plate*1 , EVA plate*2 , Anti-slip plate*1 )
4 x M5 screws nut (black color*2 , sliver color*2)
1 x Screw set
10 x 2.5x100mm Nylon cable tie
2 x Wrench
Oct 08, 2019, 02:51 PM
Fan of just about anything RC
SoloProFan's Avatar
If they kept the weak frame, it may not crash as often due to Flip of Death, as it does on 6S, but it will still have a very poor chance to survive any accidents...
Latest blog entry: For the love of the hobby!
Oct 08, 2019, 04:46 PM
(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)
JohnCC's Avatar
X140 3S-4S frame specs:
Wheelbase: 140mm
X140 3s-6s:
Wheelbase: 140mm
the frame stats are the exact same, seems unlikely they made any change to the frame at all
Oct 09, 2019, 11:41 AM
SoloProFan's Avatar
X140 3s-6s:
That is what I was afraid of. Probably same electronics as well, seems their idea of "fixing" the issues on 6S, is simply using different motors and declare it only suitable up to 4S max.
Naturally the affiliates who post the links probably won't care much about the quality of the stuff they post, or whether it is really something new, or just a recycled flawed and older design.
Oct 19, 2019, 05:40 AM
6s version - 1507/2500KV Brushless Motor
4s version - 1507/3850KV Brushless Motor
Oct 19, 2019, 08:14 AM
SoloProFan's Avatar
So they just changed the motor, and the weak frame has remained. Maybe there is hope for the 3rd version. Or maybe we first get another hv version with stronger frame, and with again flip of death, then a 4th version with stronger frame, and 4S setup, and no more flip of death.
