Jeti Central Box 210 Power Distribution Combo w/Magnetic Switch & R3/RSW Receivers
The new Central Box 210 is an improvement over the venerable Central Box 200 and is due in stock in November.
The new Central Box 210 is an improvement over the venerable Central Box 200. We have removed the overload protection at each servo output and designed an aluminum housing for those high power demand applications. The Central Box 210 features true Battery Redundancy, Ditex Servo Telemetry, Jeti EX Telemetry, and up to three receiver inputs (2x 2.4GHz and 1x 900MHz) with serial (PPM, EX Bus) output for complete Power & RF Signal Redundancy.
With Jeti Duplex 2.4GHz DC/DS transmitters, the full potential of the Central Box can be used, such as easy way to wirelessly configure the Servo Outputs, Ditex Servo & EX Telemetry, Fail-Safe Setting or Function Assignment.
Magnetic Switch (Included) The magnetic switch is used to turn the Central Box ON/OFF and is connected to a separate slot labeled "SW". To turn on the Central Box using the magnetic switch it is necessary to hold the supplied magnet (key) to the target so that the key and the target on the magnetic switch are properly oriented.
Wireless Switch R3/RSW (Optional) State-of-the-art device that sets Jeti as a leading designer and manufacturer of radio control systems. Wireless power switch is fully integrated into the 2.4GHz radio system. For first time your receiver can be turned ON/OFF with simple flipping of the switch wirelessly from the Jeti DC/DS transmitters.
Power Supply The power batteries are connected to the Central Box using MPX connectors. The Central Box allows two batteries to be connected. During use, the power is actually supplied from the battery with the higher voltage. If the voltage is the same, the power can be used from both batteries at the same time. When the voltage of the batteries is different, the power is not shared and each pack is isolated from the other. This allows you to use batteries of different capacity, number of cells and chemistry type. If the power for the Central Box is provided only from one battery, it can be connected via battery (BATT 1) Input.
Included: (1) Jeti Central Box 210 (2) Jeti Duplex EX R3/RSW 2.4GHz Receiver (1) Magnetic Switch (1) Magnetic Key
Features:
  • Control Management with Configurable Servo Output
  • Power Distribution with Two Independent Inputs
  • Heavy Duty Aluminum Case for Extra Cooling and Protection
  • Firmware Updatable via Jeti USB Adapter and Jeti Studio
  • Wirelessly Programmable Using DC/DS Tx Device Explorer
  • Independent Receiver Signal Inputs (R1, R2, E1/R3)
  • Up to 15x Standard PWM and Ditex Telemetry Servo Outputs
  • Up to 3x Telemetry Sensors Inputs (E1/R3, E2/15, E3/14)
  • Input for Included Magnetic or Optional Wireless Switch
  • Input Voltage: 4V - 8.4V
  • Output Current: 2x 20A Continues/90A Peak
  • Dimensions/Weight: 65mm x 42mm x 18mm/59g
Learn More
For pricing and more info head over to Esprit Model.
Oct 29, 2019, 08:28 PM
Wow, this looks really similar to the Frsky RB20....????
Oct 29, 2019, 09:49 PM
Sagitta Fanboy
The RB20 case design was pretty clearly based on the Jeti CB200's layout.
The CB210 is an update to the older CB200
Oct 30, 2019, 01:34 AM
The Frsky device is a blatant rip-off of the Jeti CB200 even to the point that the Frsky instruction manual copy and pasted whole sections from the Jeti manual. Frsky is shameless. See https://www.rcgroups.com/forums/show...5&postcount=11
Oct 30, 2019, 08:51 AM
Sagitta Fanboy
Umm, have you looked at the FrSky manual?
There's zero Jeti in there, it's their usual barely-there manual plus a Taranis screenshot and a chart of telemetry values. Frankly it would have been a better manual if they had copied Jeti's manual (as Jeti documentation is head & shoulders better than what FrSky produces as documentation)
The case is definitely a direct copy, down to the use of the poorly-chosen Multiplex connectors for power instead of something more robust like XT60's. Internals aren't a copy, but that's to be expected as the RB is a much simpler device than an CB200.
News Jeti Central Box 100 Power Distribution Unit (Mini Dual Redundant System) Jim T. Graham Radios 0 Oct 03, 2017 04:05 PM
Question Rc Switch and R3/RSW Straightlegger Jeti USA 1 Mar 03, 2016 07:04 AM
Mini-HowTo Using an R3/RSW to connect a non Jeti transmitter as a wireless buddy box. wfield0455 Jeti USA 9 Jan 02, 2016 07:03 AM
Discussion EX R3/RSW Wont switch on reciever JDPG2 Jeti USA 22 Mar 28, 2015 12:39 AM
Article Jeti Central Box 200 Power Distribution Unit w/Magnetic Switch Jason Cole Radios 1 Sep 04, 2013 09:40 AM
