Oct 05, 2019, 06:44 PM
GT500 and A123 Charge / Cell
Have searched the forums but cannot find the answer to this. I just received a GT500 Duo charger and was setting it up to charge my LiFePO4 battery packs - all 2 cell packs / 2500 mah.
When you set up the parameters for LiFePO4 the default Charge V / Cell is 3.65 V. I am used to charging my packs to 7.20 V at full. Was wondering if the default setting in the GT500 is on purpose or perhaps based on their charging methodology / algorithm.
I did change to 3.6 V / cell and hooked it up to a pack that was about 3/4 charged. It topped out as done at 7.14 V and I noticed the cells were slightly different, maybe 3.6 for one and 3.45 for the other. At that point I had not changed the settings to mandatory balance so that likely would account for the pack topping out as done at 7.14
My question is really the 3.65 Charge V / cell. Since that is the default should I just set it back to that or change it to 3.6 V ?
I cannot see an answer in the GT500 manual that I downloaded. I also sent a message to support at Revolectrix and got a response that someone in tech support would answer. But that was 24 hours ago. No response yet, likely due to the weekend.
Oct 06, 2019, 09:49 AM
I would also like to know if LiFe/A123 can be parallel charged. Thank you.
Oct 08, 2019, 07:58 AM
Sindland MC SAA
Howard Matos's Avatar
Good Day,
3.65 volts per cell is standard for A123 type chemistry. If your battery manufacturer has different specifications for their cells then go ahead and set the charger to their specifications.
Oct 08, 2019, 07:59 AM
Sindland MC SAA
Good Day,
Yes, as long as they are the same cell count.
Discussion Safe charging current for old A123 cells? natterjak Batteries and Chargers 23 Sep 02, 2019 10:42 AM
Discussion Revolectrix GT500 Parallel Charging Question splais Batteries and Chargers 7 May 13, 2018 06:15 AM
Discussion A123 cells, safe temp during operation and charging? DucknDive Batteries and Chargers 6 Feb 22, 2017 11:37 AM
Discussion Are the A123 cells , the only ones that can be charged at 10 A fast charge rate ? elglobie Batteries and Chargers 10 Aug 06, 2009 06:21 PM
Discussion Charging A123 cells with astro 109 upgraded with a123 chip jcm1010 Batteries and Chargers 12 Jun 17, 2008 08:31 PM
