This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Oct 04, 2019, 07:20 AM
Video
DustOff #6 - Zeta Z84 FPV Race Wing - View from my Trusty Old Runcam ;-)
#GroundControlRC #GlueAndFly #ScratchBuildPlanes
Here is a link to the Video:
https://www.youtube.com/watch?v=ivGCn09rsaY
The Z84 is a pretty nice Wing with a decent power system.
This version is the PNF that has a 2208 2600kv Motor, 30A ESC, and 5050 Prop.
I've found a 6040 or 6030 Prop works much better than the stock 5050 Prop as it produces more thrust and is more efficient.
After performing some more Test Flights with another Prop I thought it would be nice to just cruise around a bit with the view from my Trusty Old Runcam ;-)
***Note: I replaced the T-plug on mine with an XT60 Plug on the ESC
You Can Help Support Us By Using Our Affiliate Link To The Product Below. A small commission (At No Cost To You) helps us buy more items to review.
Zeta Wing Wing Z-84 Z84 EPO 845mm Wingspan Flying Wing PNP
https://www.banggood.com/Wing-Wing-Z...47791920140372
Props I used:
1pc KMP 6X3E High Efficiency Propeller
https://www.banggood.com/1pc-KMP-603...47791920140372
1pc KMP 6X4E High Efficiency Propeller
https://www.banggood.com/1Pcs-KMP-6X...47791920140372
A LIPO to use:
ZOP Power 3S 1500mAh 40C Lipo Battery XT60 Plug
https://usa.banggood.com/ZOP-Power-1...47791920140372
Gens Tattu 3S 1300mAh 45C Lipo Battery With XT60
https://www.banggood.com/Gens-Tattu-...47791920140372
Gaoneng GNB 3S 1300mAh 40C XT60 Plug Lipo Battery
https://www.banggood.com/Gaoneng-GNB...47791920140372
CNHL BLACK SERIES 2200mAh 3S 30C 11.1V Lipo Battery 24.42WH XT60 Plug
https://www.banggood.com/CNHL-BLACK-...47791920140372
Turnigy 2200mAh 3S 25C Lipo Pack
https://hobbyking.com/en_us/turnigy-...asc=3451564005
See you in the Air!
Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc
Patrons of the Channel will have Exclusive access to Aircraft Plans & Content!
See Us On Youtube | Patreon | RCGroups
Discussion How to: My Wing Wing Z84 FPV mounting with Aomway 5.8 gHz teddonald FPV Aircraft 0 Apr 21, 2016 01:15 PM
