Oct 01, 2019, 03:13 PM
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
Question
NIMH Charge Rate?
Been working with an 18V 1500 mah pack. I did some research, and found charge rates ranging from 0.1C to 1C. I initially used 1 amp (.66C) pack was barely warm, and at 150 ma it didn't even get warm.
Some discussions around determining the charge voltage involved the kind of charging circuitry in use and how it handles the increasing voltage in the pack, especially when it is close to full. I have a GT 500.
I would appreciate feedback about what sort of charge rate to use. I know slow and steady gets it done (.1C) but would like to charge the pack faster.
Oct 08, 2019, 08:19 AM
Sindland MC SAA
Howard Matos's Avatar
Good Day,
The GT500 will peak detect charge NiMh packs. If you charge too slow it may not peak and if you charge too fast it may false peak. I would try .5C and work your way up until you see it peak detects your pack and it has ample capacity (as long as this is a known good pack).
Oct 08, 2019, 04:19 PM
ruff1's Avatar
Pack very old and I'm writing it off... Ordered a lithium ion with twice the mah rating.
Discussion NIMH charge rates. 6v and a 4.8v? epoweredrc Batteries and Chargers 10 Aug 07, 2019 11:11 PM
Discussion Charging NiMH batteries past the mAh rating? LifeofBrian Batteries and Chargers 2 Oct 14, 2017 10:08 PM
Discussion Charge rate for NiMH Batteries Witterings Batteries and Chargers 17 Nov 15, 2015 04:21 PM
For 9.6V 1600ma NIMH battary what is the charge rate and charge time? clchen Electric Plane Talk 7 May 06, 2001 09:06 PM
For 9.6V 1600ma NIMH battary what is the best charge rate and charge time?(more) clchen Parkflyers 1 May 06, 2001 04:23 AM
