If it flies OK, then no.
As you are new into fpv and probably don't know what you are doing, you should practice with the defaults a bit. They usually work quite well. You can smoke motors or ESC if you don't know what you are doing and just change things. Also, without experience you can not feel the differences if you change settings. If you get more experienced, you can go through the Betaflight tuning notes. For 4.0: https://github.com/betaflight/betafl...0-Tuning-Notes For 4.1: https://github.com/betaflight/betafl...1-Tuning-Notes |
Thread Tools | |
Similar Threads | |||||
Discussion | Restored quad to defaults in betaflight rxsr won’t bind | Wiley207 | FPV Talk | 2 | Aug 31, 2019 12:13 PM |
Help! | How do I change the default position of my servos? | badatrc | Beginner Training Area (Aircraft-Electric) | 7 | May 21, 2019 08:07 AM |
Help! | Uncontrollable quad - Are my default PIDs way to high? - Betaflight | HB Crew | Beginner Multirotor Drones | 8 | Nov 21, 2016 11:46 AM |
Discussion | Default PIDs. Nose rises 20 degrees after flip | krachall | Beginner Multirotor Drones | 2 | Jul 11, 2016 01:25 AM |
Discussion | What should I change... | johnathansmith69 | Beginner Multirotor Drones | 6 | Oct 13, 2015 12:27 PM |
