This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Sep 29, 2019, 07:24 PM
old4570's Avatar
Functioning Tach
Time to check some motor prop combinations .
Brushed 8520 on the 450x wing .
30,000 rpm static Im calling it 30 , it went a little higher . So it should wind out more in the air .
Certainly explains why it's a little noisy .
1103 on the 450x wing (2s)
prop is a 3.8x3
And around 50% throttle I saw 12,000+ rpm
At full throttle ( motor cooks ) I saw a peak of 17100 rpm
For a 8000kv motor , this certainly explains why the motor is cooking ..
6A+ / 17100 rpm / 8000kv = Over proped !
If you do the math , Voltage x KV = RPM
4v x 8000kv = 32,000 rpm ( potentially on paper ) 20 something would be more realistic .
Oh man ! What was I thinking .. It's 2s ...
8v x 8000kv = 64,000 rpm ... So 40 something K would be more realistic ,
I have ordered more props , I think they are 3x2 or some such ( smaller anyways )
Will be cutting down one of the props included in the kit , I will cut and cut till I see a 5A peak .
It's good to have a functioning tach !
UPDATE
The 2nd 1103 just died !
Looks like no more 1103 for me ..
I ordered a 1105 and a 1106 ..
And I thought this Wing might be Budget , the budget is Blown !
Yippee! close out: Hyperion watt-meter II (optical tach, servo tester, local&remote logging) Ron van Sommeren Power Systems 101 Nov 26, 2019 12:27 PM
Discussion using a rcexl tach with out the ignition rotccapt DIY Electronics 3 Jul 30, 2016 02:37 PM
Help! DLE 20 TACH to Telemetry question metalwizard Radios 0 Mar 13, 2016 04:25 PM
Help! DLE 20 TACH to Telemetry question metalwizard Engines 0 Mar 10, 2016 11:25 PM
Discussion How to Setup a fully functioning DX6i with Naza-M All functions cjz89civic Multirotor Drone Electronics 6 Aug 10, 2014 08:43 AM
