Sep 29, 2019, 03:23 AM
Northampton UK
Bind to ai6b but no stock outputs
The radio was all working fine for some time and switched on for a flight and no stick response, remove receiver from quad to do independent test with power to receiver and servo plugged in and done another successful bind and no respond from any of the stick inputs, I have radio set PPM On,.,
Anyone with ideas, I've, also tried with new receiver.
Sep 29, 2019, 04:15 AM
Beach Bum
Steve FliesLow's Avatar
Which radio are you using? I only ask because the menus and options are different.
For the receiver you mention, my FS-i6x radio uses PWM signal, not PPM. Also make sure that AFHDS 2 is enabled.
Sep 29, 2019, 05:26 AM
Northampton UK
It's FS i6 radio and receiver FS ia6b, I have the AFHD2 on PPM on.
Oct 05, 2019, 11:29 AM
Northampton UK
Just got another TX to test and done the bind but still no signal to the servo, can't understand what I'm doing wrong, powering the receiver with bec in PPM port and no matter which aux channel I use for the servo just doesn't work.
Two TX's and two receivers all bind but no channel signals to servo very strange.
Discussion Frsky R9LR to R9 Module..Binding success, no servo output Scoutuas Electric Plane Talk 19 Sep 09, 2019 05:07 PM
Help! Omnibus F4v3 connected but no output Over Charged Beginner Multirotor Drones 1 Aug 20, 2018 02:14 PM
Discussion Turnig 9x, Rx binding but no signal/power Alex168 Radios 0 Mar 10, 2016 03:12 PM
Help! tx binded but no input on cleanflight rps13sr Beginner Multirotor Drones 4 Nov 23, 2015 10:39 PM
Discussion Turnigy 9X binds but doesn't output signal. guyfawkes Radios 11 Dec 02, 2014 12:51 PM
