Sep 26, 2019, 09:12 AM
Question
Electric retract pin removal
I have a bent electric retract pin does anyone have any experience with how to remove the pin?
Sep 26, 2019, 11:31 AM
J40
J40
Airplanus Erectus
At the trunnion rotation point center, there should be some type of Allen head screw, each side. Loosen and the pin should come out.
Sep 30, 2019, 08:11 AM
Cougar429's Avatar
Can confirm. You can just make out the threaded hole in the pivot below the mounting plate in the pic.
Not all have set screws both sides, but will have at least one.
Also, looking at the pin there is a good likelihood of a flat on the other half still in the trunnion so ensure you back that set screw out enough.
ps. I have been fabbing replacement pins from drill rod for years since can get that in any diameter. Old stripped allan head shoulder bolts work well too once the head and threads have been cut off.
Sep 30, 2019, 10:26 AM
Thank you
Help! Can't remove the wrist pin - OS FS 52 Surpass DYORD Engines 22 Jun 11, 2017 03:14 AM
Discussion Tip to remove stator pin? manuel v Electric Motor Design and Construction 9 Mar 28, 2017 02:34 PM
Discussion Removing pins? Naze 32 Great Crouton Beginner Multirotor Drones 6 Feb 10, 2017 01:46 PM
Discussion Any tips about how to remove pin on Tower 75ABC carb?ine? G.F. Beurling Engines 11 Nov 14, 2015 02:32 PM
Discussion Tamiya pin removal tool? What size pins? zirconx Batteries and Chargers 6 Sep 10, 2008 06:27 PM
