Sep 25, 2019, 05:10 PM
Ldm
Ldm
Ldm
Ldm's Avatar
Sig Hummer Kit
hello RCG !
I am dabbling in nostalgia from my past ! When I started in RC , the Sig Hummer was the second model I built and flew on an 049 .
Fast forward , they are selling these on ebay for $49.00 delivered so I simply could not pass this deal up !
I have not converted anything this small to electric rc .
Does anyone have any suggestions on a power /battery system ?
Thanks for the help !
Specs
SPECIFICATIONS
Wingspan: 34" (864mm)
Wing Area: 212.5 sq in (13.9 sq dm)
Wing Loading: 13.5 - 17.6 oz/sq ft (41 - 54 g/sq dm)
Length: 30.75" (781mm)
Flying Weight: 20 - 26oz (567 - 737g)
Airfoil: Full symmetrical
Sep 25, 2019, 08:40 PM
In the airplanes I have built that were that size I used a 400 or 450 size motor, a 20 amp E S C and a 1300 battery. John
Sep 25, 2019, 08:42 PM
On the airplanes I have built of that size I used a 400 or 450 size motor. John
Sep 26, 2019, 08:24 PM
Ldm
Ldm
Ldm
Ldm's Avatar
Thanks John
Is that 400 watts ?
Sep 26, 2019, 09:11 PM
I built my hammer with a 450 heli motor and 4s around 1000 watts! It is very fast!
Sep 26, 2019, 09:35 PM
Ldm
Ldm
Ldm
Ldm's Avatar
thanks buddy
Sep 27, 2019, 12:01 AM
Any 400 class motor will work 3s or 4s it all depends on if your trying to go fast and have crazy power or just a fun fly with good power. Anything from 400 watts will work.
Sep 29, 2019, 05:59 AM
Ldm
Ldm
Ldm
Ldm's Avatar
I am just looking for a fun flyer.
I even have one of these motors in my possession, possibly can use it considering I have it geared .
I would have to test different props .
“The HA2025 series motor is suitable for small models weighing 12 to 18 oz. direct drive or up to approximately 30 ounces when used with a gearbox.
HiMax
Ha2025
4200
Features:
High Efficiency
High Power
Lightweight
Replacement for 370 - 400 Motors
Specifications:
Weight: 65 grams (2.3oz)
Motor Only Max Power: 175 watts
Max RPM: 60,000 RPM
OD: 20.0mm, (.79”)
Length: 42.0mm, (1.68”)
Shaft Size: 2.0mm, (.078”)
Mounting Screw Thread: 2.5mm, max depth 3.0mm
Mounting Pattern: 16mm (.625”) bolt circle.
Oct 10, 2019, 05:24 AM
Ldm
Ldm
Ldm
Ldm's Avatar
Waiting for my power set up.
I changed a few things in the build sequence and still adding color ect.
I order larger light weight wheels and may use a magnetic hatch vs the stock set up.
Oct 10, 2019, 09:33 AM
Scirocco14's Avatar
I used a e-Flite Park 450 motor and it works very well. I use a 1600mah 3S battery in the stock hatch location. It makes the plane a little nose heavy, I needed to add about 1/2 oz at the tail.
I also added a rudder, which makes it like a little pattern plane now!
Mark
Oct 10, 2019, 10:46 AM
Pro Hoarder
turbonut's Avatar
It looks great..the colors give it a nice vintage look
Latest blog entry: In flight
Oct 12, 2019, 05:35 AM
Ldm
Ldm
Ldm
Ldm's Avatar
Thanks , it been a fun clean build .
I ordered a motor based on some advice from another thread.
I almost added rudder, now thinking back I wish I did ! I wanted something for ROG take off and without rudder it will be difficult.
Based on another thread I went with smaller power option higher KV , probably test a 6x4 thru 7x5 type props and see what the watt meter tells me
Build Log SIG Hummer Build Log radu_m Balsa Builders 30 Mar 24, 2019 05:24 PM
Build Log Sig Hummer into Q-200 Kit Bash HVACMAN 1/2A Planes 127 Jan 10, 2019 07:30 PM
Discussion Plans search for the original SIG 1/2a Hummer... Danoman812 Sport Planes 3 Jun 08, 2016 11:22 PM
power sys for sig hummer conversion jcrazyflyer Sport Planes 0 Mar 04, 2002 09:35 PM
Sig Hummer Scott C Sport Planes 3 Oct 10, 2001 03:03 PM
