May 11, 2020, 09:42 AM
nerd
AndWho's Avatar
Originally Posted by rocket_33
I just received my 100amp Smart ESC and the Programming Update Box. Unlike shown in the manual, this ESC has the cable for the throttle (with magnet around the lead, and it has a second, longer lead that is split at the end into two connectors. One connector is a single wire that is in the signal lead position, the other connector has two wires in the Positive and Negative position.
I plugged the two wire into the battery port on the Update Box and I plugged the single wire into the ESC port (confirming orientation was correct) and powered up the ESC. The Version Number came up as described in the instructions. I pressed the select button as per the manual and it says on the screen Connecting to ESC and this is where it stops. In the manual it says it would come up with the first menu item but unfortunately it does not. It stays on the Connecting to ESC screen.
Any ideas what may be happening? Has anyone run into this issue? Any tips would be appreciated
That single wire is a RPM sensor, for use with external governor and/or telemetry. The programming port is the pin header below the capacitors where the fan is connected. Disconnect the fan and connect the programming box to that pin header.
The wiring diagram in the manual is very confusing on this point.
/A
Review Horizon Hobby Spektrum Smart Technology Products Review kingsflyer Batteries and Chargers 77 Mar 29, 2020 10:29 AM
Review Horizon Hobby & HobbyZone's Delta Ray RTF with Safe Technology Review Michael Heer Beginner Training Area (Aircraft-Electric) 37 Nov 11, 2018 10:06 PM
Review Horizon Hobby & Blade's 350 QX With Firmware V2.0 with Safe Technology Review Michael Heer Multirotor Drone Talk 34 Jul 18, 2015 03:52 AM
Review Horizon Hobby ParkZone Sport Cub BNF with AS3X Technology Review dee-grose Parkflyers 22 Mar 01, 2015 04:07 PM
Article Horizon Hobby E-flite UMX Gee Bee R2 BNF With AS3X Technology Review Michael Heer Micro Ready-to-Fly 7 Dec 06, 2014 04:45 PM
