Oct 29, 2019, 12:54 PM
Just arrived!!!!!! woaaaaaaa
I will do a video unboxing and some test
Stay tuned
http://bit.ly/lukappaseidue
Nov 02, 2019, 07:30 PM
Flight time test:
HUBSAN ZINO PRO test autonomia durata di volo: Hubsan Zino Pro Flight time (7 min 46 sec)
Nov 05, 2019, 09:46 AM
t00nz843z's Avatar
Hubsan Zino Pro Long Range FPV Camera Drone Flight Test Review
The Hubsan Zino has been upgraded to allow much longer range for FPV flights of up to 4 kilometers. Other improvements include ND filter capability, and improved control gimbals. Lets take it for a test flight. Find it here.
and here is its flight demonstration.
Hubsan Zino Pro Long Range FPV Camera Drone Flight Test Review (52 min 4 sec)
Pros
- Three axis stabilized gimbal.
- 4K video camera resolution of 3840 x 2160 pixels at 30fps. Camera also includes optional ND filter capability.
- FPV video is viewed on your smartphone without need of WiFi. Instead your phone can be connected directly to the controller and drone via OTG cables.
- 3S 3000mah battery provides about 18 minutes flight time.
- Control and FPV video range of up to 4 Km.
- Advanced camera and flight mode control is available via the X-Hubsan app. Some flight mode features available through the app include Waypoints, Orbit, Optical Follow Me, Creative Video, and Line Fly. Photography parameters that can be modified include ISO, Exposure, Saturation, Contrast, and Sharpness. Video parameters that can be modified include Resolution, Frame Rate, White Balance, Color, and Video Format.
Cons
- Although capable of much longer FPV and control range than the original Zino, it is not a good idea to try to reach 4Km. The demonstrated flight time of the provided battery is about 18 minutes, and may not be sufficient to return.
- The drone has automatic visual apron landing capability. However, in multiple tries I was not able to get the drone to land on the apron with this feature activated. It always seems to lose the apron just before landing.
- Promised features of panorama still photography and creative video have not yet been implemented in the X-Hubsan app.
- Optional ND filters are also not yet available.
Nov 06, 2019, 09:49 AM
t00nz843z's Avatar
Hubsan Zino Pro 4K Video Demonstration
Sorry, no audio as this is a demonstration of unedited 4K video from the Zino Pro.
Hubsan Zino Pro 4K Video Demonstration (9 min 32 sec)
Nov 08, 2019, 09:18 PM
5Gdrone's Avatar
Flight Speed 60Km/h to 36km/h
Hubsan changed Max. flight speed from 60km/h of ZINO to 36km/h (10m/sec) of ZINO Pro. This is the major-change. Is it for the protection of "fly away" or unstable hovering and flight?
Nov 13, 2019, 01:43 PM
New HUBSAN ZINO PRO FIRMWARE released 1112
Uscito nuovo firmware HUBSAN ZINO PRO
Ovviamente il mio archivio Ŕ stato giÓ aggiornato
link ufficiale
https://www.hubsan.com/support/files...rmware1112.zip
link mio archivio
http://bit.ly/Lukappaseidue_Zino_firmware_repository
Nov 16, 2019, 02:14 PM
Long range and also flight time test
Hubasan Zino Pro: long range and flight time test: test di autonomia e di distanza (13 min 51 sec)
Nov 18, 2019, 11:58 AM
Pixelpeter's Avatar
There is a higher capacity Zino battery (5000mAh) on its way, for both the Zino and the Zino Pro:
https://www.hubsan.com/eur/index.php...roducts_id=671
Guess it'll give the Zino a bit of a more pronounced 'booty'
With this battery the Pro will probably be able to reach that promised range. BTW: should have been issued with the Pro in the first place imo.
Nov 20, 2019, 05:13 PM
Endusers Zino Pro Range Test to 4.8KM (23 min 42 sec)
Dec 05, 2019, 08:28 PM
5Gdrone's Avatar
Very stable hovering Mod !
I like his Mod.
DIY ZINO Pro Motor-Arm Mod - Flight Test Review (3 min 42 sec)
Dec 13, 2019, 08:15 PM
5Gdrone's Avatar
11.4V 5000mAh Lithium Battery Flight Time 35 Minutes for Hubsan Zino PRO:
https://www.aliexpress.com/item/4000439310939.html
https://www.aliexpress.com/item/4000449133508.html
Dec 14, 2019, 02:46 PM
Hubsan zino pro firmware update 1214
AGGIORNAMENTO FIRMWARE HUBSAN ZINO PRO 1412
HUBSAN ZINO PRO FIRMWARE UPDATE 1412
alla fine il link al mio archivio giÓ aggiornato
at the bottom my updated archive
ZINO PRO Firmware Updates
ZINO PRO firmware files
ZinoPro_FC_V1.0.15 (firmware for flight control board)
ZinoPro_Gimbal_V3.0.2.9 (firmware for gimbal )
ZinoPro_IT_V0.2.4 (firmware for camera board )
CHANGE LOG(for the drone ):
1: Added delay photography
2: Added panoramic photos
3: Added voice prompt of aircraft status
4: Added shutter speed adjustment
5: Open GPS follow
6: Optimized intelligent image following
7: Added the countdown of low power return
8: Added the countdown of serious low power slow down
Dec 20, 2019, 04:10 PM
Hubsan zino pro firmware update 1218
AGGIORNAMENTO FIRMWARE HUBSAN ZINO PRO 1218
HUBSAN ZINO PRO FIRMWARE UPDATE 1218
ZinoPro_FC_V1.0.16 (firmware for flight control board)
5: Open GPS follow
Upgrading notice :
Please do the horizontal calibration and compass calibration after update firmware
