Dec 11, 2019, 09:13 PM
Are we not men? We are DEVO!
xanuser's Avatar
Originally Posted by SteveT.
I couldn't get Fusion 360 to 'find' the Cura 4.4, so just went back to an earlier iteration.
SteveT.
oh yeah. i cant that working either.
and the estimated print time plugin no worky for me.
its like they try to do too much AND too fast with each release.
im sure theres some fix/workaround, but an update shouldn't break stuff that was already was working just fine.
Dec 11, 2019, 10:18 PM
Retired CAD guy
birdofplay's Avatar
Amen !
Dec 12, 2019, 01:48 AM
Me and a guy with a mustache
babblefish's Avatar
Well, I'll stick to Cura since I haven't had any problems with it (except for the loading from Fusion thing, but I don't really care about that) plus the support community is good and best of all, it's free.
Dec 13, 2019, 02:29 AM
SteveT.
Hi Steve
I had the same problem, but there is an easy workaround. Choose "custom" in the fusion print utility and then select "cura.exe" from wherever you have installed Cura4.4
Cheers, Roger
Dec 13, 2019, 07:41 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
Thanks, will do.
SteveT.
Latest blog entry: My shop....
Dec 14, 2019, 04:28 AM
From fusion I usually save to my computer not jump straight to Cura , that way I have a file I can access without opening fusion as it takes ages to load on my PC ,Cura only stores the last few files you download so I find it quicker to save the STL to my downloads on the PC ,mine also opened another Cura window every time I used the function in Fusion so I ended up with 2 or 3 Cura windows open and that really slows things down . Ill have to check if Cura selects automatically from fusion and see if I have the bug .
Dec 15, 2019, 08:17 AM
Lori, hey, you're home early
CarreraGTSCS's Avatar
Can I take measurements within a part in CURA? I Tinkered a hole into the crankcase of a generic WW1 rotary and resized it in CURA to fit my GP Dr1. I need to be able to measure the resized hole as I view it in CURA.
Dec 15, 2019, 09:52 AM
As far as I know you can't measure anything other than the Max X,Y and Z of the shape but if you do the math you should be able to find the size of the hole , it all gets a bit sketchy though as hole size always needs to be slightly oversized for FDM printing anyway .
Discussion For iPhone users: Free timer App available for download wubbe Hand Launch 226 Aug 17, 2017 07:45 AM
Alert FrSky Firmware for ETSI EN 300 328 V1.8.1 available for download Chase Wu FrSky 58 Nov 07, 2015 02:30 AM
Discussion RealFlight Add-Ons Volume 3 now available as free download for G4 KE Ryan Simulators 2 Jun 24, 2008 05:06 PM
Westek Little Bee available for free Download! Andreas Scratchbuilt Indoor and Micro Models 1 Dec 07, 2001 04:05 AM
