Sep 23, 2019, 09:23 PM
I just want to go fly!
walter3rd's Avatar
Build Log
Mini duelist electric build
Iím starting the baby brother to my larger Dave platt dualist. This little 35Ē twin will be electric with fixed trike gear. Twin 50 watt himax stick mount motors on 3s power. Tried to get some first steps going tonight and am missing the very first part! 3-32 brass tubing for the nose wheel steering assembly. I donít think I lost it but canít find it. Might have been missing in kit. Oh well Iíll grab it at the hobby shop I hope... going to be a slow build for me as there are not many pictures and delicate builds might be a bit tricky. Time will tell. Walt. Picture of big brother. I might cover the same for fun...
Sep 24, 2019, 09:33 PM
Low And Slow 3D Pilot
OliverW's Avatar
awesome!
Sep 28, 2019, 07:30 AM
walter3rd's Avatar
I’ve started the build. It’s going to be a slow one but at least it’s moving in the right direction. I promised myself I would finally get around to doing the maiden on my biggest build to date before starting another build. So I’m already breaking my promise. ��. Bridi killer bee 80”. Nose wheel brass bushing lashed to former and laminated wing mount former. Hoping these motors work well. I have no experience with himax or using stick mounts. I’ve never built a plane this small and delicate compared to my sig wonder it seems complicated
Sep 28, 2019, 07:59 AM
Obviously I'm a "Minus Member"
buzzltyr's Avatar
Walt, smaller models can seem pretty delicate. But once you get some of the basics done, they usually get sturdy. Breaking 1/8" (or even 1/16") stringers can be an occasional occurrence in regular handling.
I noticed the motors you purchased are a bit bigger than the ones recommended. Just a bit longer, same diameter. You should be OK. One thing I would check is the prop clearance between the motor and the fuselage. The motors you have show a suggested prop of between 7 and 10". If you can fit a 9" prop, you should be OK. I would suggest a 3 cell lipo for power. A two cell would require a larger diamenter prop.
I will follow along with your build. I have looked at this kit a bunch of times, but just haven't gotten around to acquiring it. Too many others in the queue. Paul Bradley (the designer) puts out some very nice and well designed models, so I think it should go together well.
Mark
Sep 28, 2019, 02:01 PM
walter3rd's Avatar
thanks. the slightly smaller version of this motor said for 2s and i wanted a 3s power system so i was hoping this would work. the plans recommend a 6 prop and i thought i could make due with this motors recommended 7 possibly, we shall see. it should be a fun adventure and im always up for a bit of kit bashing if required.
Sep 28, 2019, 03:16 PM
buzzltyr's Avatar
If you scroll down a bit, you can get some idea of prop size from this chart:
https://www.radicalrc.com/category/Himax-Outrunners-114
A 7x6 seems to be about the right wattage, if you can fit it. If only a 6" prop will fit, you might consider a 4 cell battery, per the chart. The two issues for a 4 cell setup would be a 4 cell capable ESC (in a 8-10 amp size) and sufficient space in the fuselage to fit the battery.
Mark
Sep 29, 2019, 11:11 AM
walter3rd's Avatar
I’m going to hope for 3s power and prop clearance. Fingers crossed. I’ll be sure to watt test everything as well
Sep 29, 2019, 11:54 AM
Steve Merrill's Avatar
Iíve used those little Himax motors, good quality!
Sep 29, 2019, 12:12 PM
walter3rd's Avatar
Awesome
Sep 29, 2019, 01:45 PM
walter3rd's Avatar
Almost done.... ��tacked with ca. Question what size servos are people using on this build ?
Oct 03, 2019, 05:53 PM
walter3rd's Avatar
More goodies arrived today I can’t believe how small these esc s are! So tiny. Not used to working with such little gear.
Oct 04, 2019, 10:13 PM
PaulBrad's Avatar
The joy of building smaller RC models. Many of the smaller models we build today would not be practical without the availability of the small RC gear. Motors, servos, ESC's, and of course smaller batteries to fit in those small nacelles.
I look forward to watching your progress on this build.
Paul Bradley
Oct 05, 2019, 12:10 AM
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
Iím going to hope for 3s power and prop clearance. Fingers crossed. Iíll be sure to watt test everything as well
You could always try some of the 3-blade drone props. I've even seen 4 and 6 blade ones. With that low KV motor your gonna have a hard time loading it up if your limited to 6" diameter.
Oct 05, 2019, 08:10 AM
walter3rd's Avatar
Good idea! I would love 3 or4 blade props as well. I will look into that for sure.,thanks
Oct 05, 2019, 10:45 AM
walter3rd's Avatar
Just placed a order for a couple 600 mah 3s batts. Figured I just get two since I’m not sure if I want to fly with smaller or larger battery packs. Wanted to test first before I commit to Quantity. Soldered on the motor connectors to the ESC’s. Want to wait for my batteries before I do my connections to make sure I do the right ones. ordered some counter rotating 3 and 4 blade props to have something to test as a starting point.
Discussion Electric Duelist Mk II Bob Hunt Glow to Electric Conversions 262 May 02, 2019 01:20 PM
Question New to Electric,building a mini-telestar John Horvath Beginner Training Area (Aircraft-Electric) 2 Jul 01, 2005 02:08 AM
electric duelist mj smith Sport Planes 48 May 25, 2005 09:29 PM
Mini-Nyx Electric Build Questions Meneer High Performance 44 Jul 18, 2004 07:15 PM
Mini-Nyx Electric build questions Meneer Electric Sailplanes 0 Jun 10, 2004 01:42 PM
