Oct 28, 2019, 09:43 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Originally Posted by birdofplay
Not to worry, I can do it on MPF fer sure.
DXF files on their way Bob
Tony
Oct 29, 2019, 06:57 AM
Lockey's Avatar
I have started the Swept wing version
This is made from the "NEW" Depron .. or as its now called "Modelling Foam" its a lot softer than Depron but it seems "Real Depron" is no longer and will not be available again
I put the booms in place and then fitted the KFm airfoils, then removed the booms to make it easier to sand the leading edge of the wing, I used quite a bit of CA glue on this one but still used hot melt glue for the majority of the build
I have started using the fiberglass tape for the hinges (both sides) and its also very quick and easy to make hinges this way .. https://hobbyking.com/en_us/high-str...0mm-x-50m.html
I have moved the motor forward about 50mm so this should help with thee C of G and a better battery choice .. hopefully it doesn't upset the way it flies, I have also moved the step forward nearer to the new CG
5mm round CF spar in the wing and horizontal stab were glued in using hot glue and the 5 x 1mm CF flats used in the booms were glued in using CA
About 6 hours work after parts were all cut out ,, it goes together really quickly
Lockey
Oct 31, 2019, 01:29 AM
Lockey's Avatar
More Build
Ready to maiden .. AUW with 2200 /3s battery is 730 grams
This one has https://hobbyking.com/en_us/turnigy-...ner-motor.html with a 8x4 prop and 40A ESC, I hope the motor is powerful enough for it
Lockey
Oct 31, 2019, 05:10 AM
Lockey's Avatar
The twins together .. Delta wing 850 mm span ... Swept wing 990 mm span
Lockey
Nov 02, 2019, 01:31 AM
Lockey's Avatar
AND .. its about time we had an EDF version of this one .. shown with a 70mm EDF
Lockey
Nov 02, 2019, 10:42 PM
Lockey's Avatar
Maidened the swept wing version of the Viking this morning and it flew great .. now I know where the CG is meant to be, it flew straight off the drawing board and didn't need even one click of trim .. I thought that was amazing
They both fly similar, but I think my preference would be slightly towards the swept wing version
Lockey
Viking Swept Wing Maiden (4 min 0 sec)
Viking swept wing Second flight (3 min 26 sec)
Viking Delta Wing short flight in the wind (1 min 57 sec)
Nov 02, 2019, 11:54 PM
When cows fly!
Nice!
Nov 03, 2019, 06:36 AM
Lockey's Avatar
Thanks David
I decided to do the EDF mods on the Delta because it was a real shame to hack up the swept wing as it flies so damn nice
Anyway .. here it is
Lockey
Nov 03, 2019, 08:56 AM
Retired CAD guy
birdofplay's Avatar
Very nice Dynamic Duo you've created.
Can't wait to see the EDF version to blast off !
As many contortions as the EDF intake has you must have warmed it up to 100C !
Do you have closable Cooling holes for water Operations ?
Nov 03, 2019, 07:42 PM
Lockey's Avatar
Thanks Bob .. yes I did a bit of "foam modeling" with the intake, but will definitely simplify it on the plans
I did "sort of" think about the intake cooling holes and YES they will have to be changed for water flying eh maybe the old "plastic spoon" cut down scoop or the Coke bottle bottom air scoop .. will elaborate on these later
By the way, I know the EDF seems to point down .. but in actual fact (it should be) pointing up a little to mach the horizontal stab (as did the motor/prop) which is 2 degrees positive incidence to the wing (front of stab pointing down .. back pointing up)
It maybe looks this way as the exhaust cone is tapered .. see pic
Lockey
Nov 03, 2019, 09:29 PM
Retired CAD guy
birdofplay's Avatar
Good to hear.
I have an 11 blade EDF ~ 60mm that has never been used .
This might be a better use than that fan trainer.
Nov 03, 2019, 09:56 PM
Lockey's Avatar
Good to hear.
Just flew the Delta with a 12 blade EDF .. https://www.rc-castle.com/index.php?...0Kv+EDF+For+4S
It flew great .. again no trim needed
I think the EDF came unglued (about 1.34 minutes into the video) as I only really tacked it to the foam cowl with a bit of hot glue .. silly me oh well another crumpled nose David
Lockey
Viking Delta with EDF mods (4 min 17 sec)
Nov 04, 2019, 09:18 AM
Retired CAD guy
birdofplay's Avatar
Quite right ! Good Show !
With much less racket then a Prop 'er !
Terrific ground handling too.
Now take a Chill Pill and relax ;>}}}
Nov 04, 2019, 06:43 PM
Lockey's Avatar
Bob, I was really pleasantly surprised how quiet the new 12 blade EDFs are, we always think of EDfs as quite noisy little screamers but this one was more of a swoooosh
I thought the larger prop would have made it a bit quieter but seems not so much
Plastic spoon air intake and exhaust I mentioned in an earlier post
Lockey
Nov 04, 2019, 08:08 PM
Retired CAD guy
birdofplay's Avatar
I knew that was where you were going with your comment.
Or at least something like that.
Great minds think alike .
Or at least on the same Frequency.
It's better than throwing them in the ocean.
Is the EDF well balanced and smooth running ?
My FMS 50mm is the 1st "plastic" EDF that I've found to be so.
And it seems very efficient and reasonably powerful too.
Maybe "they" have finally figured out how to make these things.
I DO LIKE the Whoosh and quietness of the dampened whine.
Those old 4-5 blade EDFs were just inefficient, noisey AMP EATERS
Discussion Need motor advice for 850 mm boat. Electric Graupner Key Biscayne rccp Racing Boats - Electric 25 Jul 08, 2017 05:12 PM
Build Log 1200 mm Span Sailplane/Glider (Now a Slipso 400 inspired pylon racer) Toomb Raider Foamies (Scratchbuilt) 2 Jul 16, 2016 07:34 PM
Discussion Launching 800 mm Span Warbirds? sterob Electric Warbirds 10 Jun 16, 2014 06:44 AM
Discussion 700 mm Wing Span - Ailerons -What is the Solution? rcmaverick Electric Plane Talk 3 Aug 02, 2012 11:48 PM
Question Airsail's Auster AOP 9 - 620 mm span Tobi Scratchbuilt Indoor and Micro Models 44 Feb 06, 2011 08:36 PM
