Oct 22, 2019, 09:18 AM
Retired CAD guy
birdofplay's Avatar
say you'r up late ;>}
re Ladybird
Oh yea I forgot about that one.
Well, then ... it's got to be all of the Fuse side.
The Ladybird has a lower fuse as does the Vixon.
I am at a loss to explain this mystery
Oct 22, 2019, 09:24 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
re Ladybird
Think you could be right Bob, also the fuselage bottom must be giving lift too to bring the CG so far forward (almost to the front of the wing (amazing really)
Maybe I should remove the fuselage altogether and start again with a new fuselage
Lockey
Oct 22, 2019, 09:39 AM
Retired CAD guy
birdofplay's Avatar
Even With the Cg so far forward the nose did not drop off in a turn.
It's like automatic Knife Edge.
I don't think I ever built the Lady Bird, but I have it on Depron - wheew that was a long time ago.
I may transfer to MPF an have a go .. some time this upcoming Long winter building season.
Oct 23, 2019, 12:08 AM
Lockey's Avatar
I have decided to give this one another go and lower the top fuselage by 30mm to see if it will take away some of the strange behavior
I was able to re-use the top fuselage section (with motor intact) but made a new front and bottom fuselage section, although I could have reused the rear section of the fuselage too
I will use a 4s battery on the next test flight
Lockey
Oct 23, 2019, 06:50 AM
Lockey's Avatar
Ready to test fly again, same motor will try with 8 x 6 prop and 4's battery
Lockey
Oct 23, 2019, 12:39 PM
Foamy and Glider fanatic
Blacky's Boy's Avatar
Lockey,
You are one of the few guys I've seen that can take a crashed airplane and make the repairs look seamless. Well done!
Oct 23, 2019, 06:36 PM
Lockey's Avatar
Originally Posted by Blacky's Boy
Lockey,
Thanks BB appreciate your comment .. now .. if only I could do the same with my tied and worn body and face
Lockey
Oct 23, 2019, 08:36 PM
Retired CAD guy
birdofplay's Avatar
I can't make new builds look that good.
Can't wait to see if it flys differently.
Oct 25, 2019, 12:50 AM
Lockey's Avatar
Bob.. Viking now flies like its on rails .. BIG improvement .. the fuselage must be acting like a wing and adding quite a lot to the wing area because the CG is WAY further forward than you would think .. about 70mm (2.7 inches) further forward than the step which is where it is on the Vixen
Video later
Lockey
Oct 25, 2019, 02:35 AM
Sokol
JureZ's Avatar
Originally Posted by Lockey
Bob.. Viking now flies like its on rails .. BIG improvement .. Video later
Lockey
congratulations Lockey ! well deserved success !
Oct 25, 2019, 02:56 AM
Lockey's Avatar
Thanks JureZ, appreciated
Lockey
Oct 25, 2019, 04:54 AM
Lockey's Avatar
Hey Bob, here is the video
Lockey
Viking Re maiden with new lowered fuselage (6 min 35 sec)
Oct 25, 2019, 09:04 AM
Retired CAD guy
birdofplay's Avatar
Woo Whoo !
I"ll be modifying mine shortly !
Oct 28, 2019, 08:04 PM
Lockey's Avatar
Now this one flies good, I think I might build the swept wing version
Have almost finished the plans for both if anyone is interested in building either one of these .. AND ... Bob https://www.hoosiercutoutservice.com will soon have the files to cut either one.
I have managed to get it (either one) from 2 full sheets of Depron (1000 x 700) .. not sure how Bob will go using MPF
Guess it will now have to be "Viking-S" and "Viking-D" .. for "Delta wing" and "Swept wing"
Lockey
Oct 28, 2019, 09:28 PM
Retired CAD guy
birdofplay's Avatar
Not to worry, I can do it on MPF fer sure.
Discussion Need motor advice for 850 mm boat. Electric Graupner Key Biscayne rccp Racing Boats - Electric 25 Jul 08, 2017 05:12 PM
Build Log 1200 mm Span Sailplane/Glider (Now a Slipso 400 inspired pylon racer) Toomb Raider Foamies (Scratchbuilt) 2 Jul 16, 2016 07:34 PM
Discussion Launching 800 mm Span Warbirds? sterob Electric Warbirds 10 Jun 16, 2014 06:44 AM
Discussion 700 mm Wing Span - Ailerons -What is the Solution? rcmaverick Electric Plane Talk 3 Aug 02, 2012 11:48 PM
Question Airsail's Auster AOP 9 - 620 mm span Tobi Scratchbuilt Indoor and Micro Models 44 Feb 06, 2011 08:36 PM
