Sep 21, 2019, 12:20 PM
deadaim57's Avatar
Question
is there a way
Is there a way to rebuild a MJX X101 so it would bind with my Fly Sky radio?
Sep 25, 2019, 07:14 PM
Im sure there is you need to buy a receiver if you dont have one that you can bind with that transmitter.
Then pull out the helis one and install it. test then fly
Sep 25, 2019, 07:32 PM
FA3PR9WM79
Oldgazer's Avatar
This would depend on how the flight controller and receiver circuitry are built and integrated.
However, a better option would be to leave the Bugs alone and see if you can use a Multi-Protocol transmitter module (AKA an MPM) with your TH9x.
Check this thread: https://www.rcgroups.com/forums/show...ocol-TX-Module
Discussion Is there a way to reverse motor direction on the fly? webbeing Power Systems 9 Nov 18, 2015 09:46 AM
Question Is there a way to completely block a sub-forum? BillzillaAus Site Suggestions / Complaints 3 Oct 27, 2015 07:36 AM
Question ABC or ABN...is there a way to tell? Eugene Chernosky Engines 41 Oct 09, 2015 08:30 AM
Suggestion Is there any way that I can duplicate an expired listing? ShockWave Site Suggestions / Complaints 1 Oct 09, 2015 07:22 AM
Discussion Is there an easy way to check motor spin direction before the quad is built? nickpapagiorgio Mini Multirotor Drones 7 Sep 16, 2015 04:02 PM
