Sep 18, 2019, 09:17 PM
Merch's Avatar
New Product
GEPRC MARK4 HD5 DJI FPV 224mm 5 Inch Frame Kit Compatible With DJI FPV Air Unit
Specifications:
Brand: GEPRC
Item name: MARK4 HD5
Frame type: H-TYPE
Propeller : 5inch
Motor to motor: 224mm
Mounting Holes: 30.5*30.5mm/20*20mm
Weight: 121g
Arms plate : 5mm
Side plate : 2.5mm
Top plate : 2.5mm
Bottom plate : 2.5mm
Protect plate : 2mm
Recommended Parts:
Flight Controller: RF/Kiss/F3/F4/F7
Motor: 22xx/23xx/24xx/25xx
ESC: 30A-50A
Propeller: 5inch
Lipo: 4S 1500mAh ~ 6S 1300mAh
FPV JI FPV Air Unit
Features:
The perfect match DJI FPV Air Unit
3D printing parts are fixed and protected
No propeller in the view
Full 3K Carbon Fiber Frame
Super lightweight Freestyle frame
Beautiful appearance design, durable in crashing
Quick maintenance Arms and replacement of equipment
25mm standoffs for better height and CG relation,Ample space for electronic installation
ALU6061 Srandoff New , Strengthen the hardness
There are 30.5*30.5mm and 20*20mm flight control holes , Stack can fit in the center or the rear.
High quality 3K twill carbon fiber plate, high precision CNC processing
YFS screw, 12.9 grade strength, non-slip teeth, anti-rust,Durable steel hardware
Package Include:
4 x 5mm 5inch Arms plate
2 x 2.5mm side plate
1 x 2.5mm top plate
1 x 2.5mm Bottom plate
2 x 2mm Bumpers plate
2 x 2mm Reinforce plate
1 x Lipo silicone pad
1x DJI FPV Air Unit fixed
1x Antenna Mount
1x RX Antenna Mount
Discussion iFlight SucceX F7 TwinG STM32F722RET6 Flight Controller W/ OSD Dual ICM20689 Blackbox alex_nikiforov Banggood.com 6 Oct 18, 2019 09:30 AM
New Product iFlight SucceX F7 TwinG Mini-W F7 Flight Controller & 40A 2-6S BL_32 ESC & 48CH 500mW Merch Banggood.com 0 Sep 02, 2019 09:17 PM
New Product iFlight SucceX F7 V2.1 TwinG Flight Controller + SucceX 60A V2 Plus BLHeli_32 4-in-1 Merch Banggood.com 0 Jul 24, 2019 05:28 AM
New Product iFlight SucceX F7 TwinG Plus F7 OSD Flight Controller & 50A BL_32 4in1 ESC Stack alex_nikiforov Banggood.com 0 Apr 07, 2019 08:55 AM
