Sep 18, 2019, 12:12 PM
Battery Junkie
wrenwright's Avatar
Question
Prop adapter for 3/8" shaft
I'm looking for a collet style prop adapter that will mount a prop on a 3/8" motor (or gearbox) shaft. I believe Astro Flight used to make them, but they no longer do.
Any ideas?
Thanks.
Sep 20, 2019, 03:59 PM
Battery Junkie
wrenwright's Avatar
How about one for 5/16" or 8mm?
Anyone, Buller?
Sep 20, 2019, 07:28 PM
I'd rather be Flying
davecee's Avatar
Here's one for 8mm motor shaft.
https://www.espritmodel.com/prop-shaft-adapters.aspx
Sep 20, 2019, 09:35 PM
If it flies, I can crash it.
rocketsled666's Avatar
Does it have to be a collet adapter? The adapter type that locks on with a grub screw can probably be had in something close, like 8mm, and then easily drilled by hand with a 3/8" bit. You'd just have to file a flat spot on the shaft for the grub to bite.
You might be able to drill out a collet adapter if you clamp it down really tight. But you'll want a sharp bit and a high drill speed and a slow plunge rate.
3/8s is 9.5mm. I don't think an 8mm collet will seat properly over a shaft that's almost 20% larger.
Sep 21, 2019, 06:12 AM
davecee's Avatar
In the second post, he asked for an 8mm collett adapter.
Discussion prop reamed too wide - adapt for smaller shaft? harttvboy Power Systems 5 Apr 04, 2017 08:38 PM
Discussion Prop adapter for 5mm shaft: need a longer one sothpaw Power Systems 8 Jul 28, 2016 06:26 AM
Question Where can I find edf shaft adapters for 2 and 2.3 mm shafts? gtinbm Electric Ducted Fan Jet Talk 4 Feb 10, 2016 04:22 PM
AC prop adapters for 3.0 mm and 3.2 mm shafts Dr Kiwi Power Systems 10 Apr 03, 2004 02:02 AM
Gunther prop adapter for 3.2mm shaft? bmiller Power Systems 1 Jul 26, 2002 11:49 PM
