Sep 18, 2019, 03:18 AM
eYeboxFPV
victorbah's Avatar
EXTRA300 GF (glue free)
After many crashes, my EXTRA300 foam got a new fashionable case.
The design includes a body, wings and chassis assembly.
Assembly without the use of glue.
This makes it possible to quickly replace parts after their destruction. It is possible to use foam wings that remain from the original aircraft.
There is space for installing FPV equipment in the cab.
The plane flies very well.
Print files I posted thingiverse
https://www.thingiverse.com/thing:3866541
Build and Flight Video
3Dprint RC plane по мотивам Extra300 (20 min 0 sec)
Sep 18, 2019, 03:45 AM
Kudos!
Hi,
I also try to make as much as possible demountable.
But this is by far the best I've seen so far.
My compliment. Hats off!
Michael
Sep 18, 2019, 11:26 AM
Patrick Randall
randallp's Avatar
Excellent!
Sep 18, 2019, 01:55 PM
the stl has some errors would be possible to correct, what is the electronic itilized?
Sep 18, 2019, 03:15 PM
eYeboxFPV
victorbah's Avatar
Models contain double walls with a thickness of 0.05mm and this may cause an error for some print programs 3d, however S3D and cura4 have successfully handled printing. Which files do you have causing a print error?
Sep 19, 2019, 02:53 AM
With which extrusion width are printed the parts?
Sep 19, 2019, 03:25 AM
eYeboxFPV
victorbah's Avatar
I printed all parts 0.42mm except the tail and К4 К5 which I printed 0.38mm.
print stab
Print stab (0 min 19 sec)
Sep 19, 2019, 05:18 AM
It would be interesting to make a tutorial with the parameters of each printed part, and which motor used and the battery and servos, I use simplifly 3d as a slicer
Sep 19, 2019, 06:41 AM
rajazo's Avatar
Impressive work Víctor!
Can you post more info about the plane like:
AUW, dimensions, motor specs, servos
And about the printer, is it possible to print 0,05 on a 0,42 nozzle? Or is just a trick to force the printer to make a double wall in near the same place? How much is the total thickness of the perimeter? Can you take the dimensions with a caliper?
Thanks!
Sep 19, 2019, 03:07 PM
eYeboxFPV
victorbah's Avatar
Wingspan of 1000mm, weight of printed parts about 650g, take-off weight with battery 4S1600 - 1100g.
Motor I used the one left from foam plane 3536-1100kv weight 150 g
air screw 10х5
servo 9 g
Start printing k1
I recommend 2 processes.
We print the lower cover in 2 layers and 2 perimeters to the height of 2 mm, and then the process with one perimeter in the vase mode and without covers. In the end, we get such a detail.
If only one process is used, then another cover will be printed inside at a height of 3mm (see figure) and it will then need to be removed with a hot knife
Sep 20, 2019, 03:36 AM
Great work. Can you please share your factory files?
Discussion 3D Acrobatic Glue Free 3d Berridi 3D Printed Planes 6 Feb 13, 2019 02:27 PM
Discussion What is a good glue to glue motor mount to Mini Skywalker styrofoam frame? vdubplate Electric Plane Talk 10 Mar 01, 2016 05:40 AM
Discussion multiplex extra300s vs fms yak54 slufpilot 3D Foamies 0 Dec 12, 2015 03:34 AM
Discussion Any other glue besides epoxy to glue wing halfs together? mgdon Beginner Training Area (Aircraft-Electric) 7 Nov 25, 2015 09:26 PM
Download free plans site I found. Extra300s,Sukhio,Ultimate & many more rcgolf Electric Plane Talk 1 Sep 29, 2006 03:32 AM
