Sep 18, 2019, 12:24 AM
Help!
Motor running very stiff
Hi guys,
Sorry if this is the wrong place to post, but I have a brushless outrunner, and it is running very stiff, meaning that the shaft will not turn freely, and last time I ran it up smoke just poured out of the sides, but it still ran confusingly My guess is that the smoke came from all the friction from the motor binding. Does anybody have any idea how to fix this?
Sep 18, 2019, 04:16 AM
Has the motor been in a crash?
If smoke came out then it is very likely the motor will have to be replaced.
Clearly if it is stiff there is something mechanically wrong with it and trying to run it has overloaded the motor. It is likely the wires inside got hot and started to burn the insulation around them. Not repairable.
If the motor has been in a crash the motor shaft may be bent or one of the magnets has become loose.
You would have to take the motor apart to find out what was wrong and even then it may not be fixable.
The simplest solution is to replace it.
Help! Motor Running cool, but wire very hot! khawajaareeb Car Talk 13 Mar 10, 2017 02:11 AM
Discussion motor stiff after run rhuber40 Electric Motor Design and Construction 6 Aug 23, 2011 06:47 PM
alfa p-47 control surfaces-very stiff TMO Parkflyers 7 Oct 30, 2003 04:28 PM
Heavy, Ugly SS landing gear mod (but cheap, easy and very stiff) flipnidaho Parkflyers 3 Jul 18, 2003 01:46 PM
Some VERY stiff-water float flying! mefly2 Parkflyers 30 Oct 18, 2002 11:32 PM
