This thread is privately moderated by MIKEYOUR, who may elect to delete unwanted replies.
Sep 17, 2019, 06:44 PM
Trader Rating: 354
"Thats right Iceman"
For Sale
phoenix models 1/5 mxs with scorpion 4020-12
Pristine condition flown 2 times
Phoenix models 1/5 scale MXS (200$ )
4 JR ds821 servos cost (140$)
comes with 2 batteries cost (120$)
comes with receiver AR8000 cost (120$)
scorpion 4020-12 cost (150$)
Castle ICE 100 ESC cost(100$)
Total 830$ costs
Build time FREE
My price 400$
Heres the review: https://www.rcgroups.com/forums/show...raft-GP-EP-ARF
Motor specs;Motor Specifications
Io = 1.92A at 21V
Kv = 542 rpm/volt
R = 0.020 Ohms
Length = 41.2mm
Diameter = 48.7mm
Weight = 304g
Continuous current accepted = 85A
Maximum continuous power = 1850W
Shaft = 6mm carbonised steel (protrudes both ends)
Collet-type prop adaptor and back-mount supplied
Motor fixing = four 4mm bolts supplied
Male 4mm bullet connectors fitted to motor
Recommended controller = Hifei ESC
An LRK (outrunner) brushless motor for R/C aircraft up to 8.0 kg powered by 12-18 cells or 4-6S LiPo; suitable for cabin models, scale models, aerobatic models and gliders - this motor can easily replace .90 two stroke engines. No gearbox is required because of the high torque of this motor type.
All Scorpion 4000 series motors have 3 ball bearings to support the rotating housing.
This is one gutsy motor - capable of high amps and great power output up to 1500W!
The S40 series of motors from Scorpion all have 40mm diameter stators - there are 12 stator arms and 14 magnets in the rotor housing. The stator is 20mm long in this 4020 version. The motor wind is a 12 turn delta wind with 22 strand 0.25mm wire.
Prop for 4S - 18x12"
Prop for 5S - 16x10"
Prop for 6S - 14x10"
Phoenix Model 1/5 MX Aircraft MXS GP/EP ARF (2 min 40 sec)
Wanted Phoenix Models 1/4 1.20 MXS Fuselage and Tail Assemblies Bigflyer60 Aircraft - Fuel - Airplanes (FS/W) 0 Aug 04, 2018 02:49 PM
Wanted Phoenix Models 1/4 1.20 MXS Fuselage and Tail Bigflyer60 Aircraft - Fuel - Airplanes (FS/W) 0 Aug 04, 2018 02:38 PM
Discussion Phoenix Model 1/5 MXS stratoblaster Fuel Plane Talk 2 Dec 29, 2016 12:10 PM
Discussion Phoenix model MXS 1/5 on sale AirMonty Hot Online Deals 9 Dec 17, 2016 06:03 PM
Review Phoenix Model and Tower Hobbies 1/5 MXS Aircraft GP/EP ARF Michael Heer Sport Planes 5 May 25, 2016 10:56 AM
