This thread is privately moderated by Miami Mike, who may elect to delete unwanted replies.
Sep 17, 2019, 08:45 AM
e^(iπ) + 1 = 0
Miami Mike's Avatar
Alert
Flight Sim Issue From Windows 10 Update
Reports are appearing of a recent Windows 10 update disabling and replacing the driver that enables use of an FrSky radio as a USB flight simulator controller.
Here's the first report I saw, along with a fix:
Originally Posted by filago
Hello folks, I frequently use my Taranis (X9D, using OTX 2.1.9) as the controller for PicaSim flight simulator on a Windows 10 PC, and yesterday it suddenly wouldn't work for that.
In case it helps anyone else, here is a quick summary of how I got it working again.
Symptom: After a Windows update, the game controller functions (joysticks, switches) no longer do anything in Windows.
Cause: Windows update installed a new driver "libusb0.sys" in "C:\windows\system32\drivers" which was now being used for the Taranis USB inputs.
Solution: Revert back to the previous Windows driver.
  • Turn Taranis ON, and attach to PC via USB as normal for using flight simulator.
  • Go to Control Panel > Devices and Printers. Right click on item "FrSKY Taranis…" Select Properites > Hardware > USB Input Device > Properties > Change Settings > Driver > Update Driver > "Browse my computer…" > "Let me pick…"
  • Windows had switched mine to "BETTER_USB_HS" (which in this case was NOT better!)
  • I switched it back to "USB Input Device" and all is good again.
It is once again using the driver "hidusb.sys" in the same directory as above, and the game controller functions are working as before.
Cheers,
- John
I found that in my case the procedure to get to those settings was different than what was described by John, so it's not necessarily the same for everybody.
Here are some other reports that I've spotted so far:
Dcchr - https://www.rcgroups.com/forums/show...45&postcount=1
Griggs2121 - https://www.rcgroups.com/forums/show...postcount=9957
David Galati - https://www.rcgroups.com/forums/show...ostcount=33271
Please post below with any questions, comments, corrections, alternate procedures, videos, additional resources, etc.
Sep 18, 2019, 12:03 AM
Fixing FrSky / Jumper Tx after windows update to libusb (3 min 6 sec)
This is the fix
Now if you cant rollback and that button is grayed out then go to this page https://batcavegames.freshdesk.com/s...o-stop-working
Now if you are like me and this doesn't work then you will have to go to Zadig and click on the frsky driver and change it to the libusb driver. When you do that then you will see it in device manager then go to the batecavegames link above and do what it says. That will fix it.
Oct 11, 2019, 10:00 AM
what goes up, must come down..
You guys are ALL SO AMAZING!!! I have tried fixing this (with no help from Horizon support) for almost a month after the stupid Windows update! I am SO glad to finally have this fixed! thanks for posting this!
Cheers!
-Clint
Oct 11, 2019, 11:08 AM
e^(iπ) + 1 = 0
Miami Mike's Avatar
I haven't had this happen to my own computer yet, probably because I have Windows 10 Pro and can delay (but not stop) updates that Windows 10 Home users can't. But since I know I'll eventually get the update forced on me by Microsoft, at least when that happens I'll be able to consult my own blog post here to see how to fix it.
Discussion Windows 10 April Update (version 1803) Problems? Zaurak3 Life, The Universe, and Politics 25 May 17, 2018 07:32 PM
Mini-HowTo FSOne v1 Flight Sim update problem FIXED KillerRabbit Simulators 0 Jan 14, 2018 05:27 PM
Discussion New Windows 10 Update today josephr Multirotor Drone Electronics 3 Apr 15, 2017 02:58 AM
Help! Phoenix Flight Sim Update from V2.5 GLHS592 Simulators 0 May 25, 2016 06:39 PM
Discussion Don't want Windows 10? No problem, upgrade to Windows 3.1 instead Sonny McGhee Life, The Universe, and Politics 20 Feb 18, 2016 11:05 AM
