Sep 16, 2019, 10:50 PM
Merch's Avatar
RunCam Hybrid 4K 30fps FOV 145 Degree HD Recording DVR Dual Lens Mini FPV Camera Low
RunCam Hybrid 4K 30fps FOV 145 Degree HD Recording DVR Dual Lens Mini FPV Camera Low Latency Single Board for RC Racing Drone
Description:
Brand : RunCam
Item name : hybrid
Color : Black
Parameters :
HD sensor SONY 8MP
Analog sensor SONY 1.3MP
Field of View (FOV) HD Recording FOV 145(FPV FOV: 150 @ 4: 3)
Video Resolution [email protected] / [email protected] / [email protected] / [email protected] / [email protected] / [email protected] / [email protected]
Video File Format MP4
TV Mode NTSC (720*480)/PAL (720*576) Switchable
Interface HD supports UART remote control; Analog supports UART fimrware update.
Max Micro SD CardSupported Up to 128G. U3 recommended (2.7K60/1080P120 requires U3 or above; other solutions require U1 or above) Please make sure that the file format of the SD card is FAT32, otherwise, it will easily cause errors.
Mounting Hole Distance 20*20mm
PCB Size 29*29mm
Lens Module Size 19*25mm
Lens Specs HD M10 ; Analog M8
Power Input DC 5-20V (Non-direct power supply from 4s battery or above. Powered direcly with battery will generate surges and burn the camera.)
Working Current 480mA @5V / 140mA @12V
Weight 18g
Features :
-True 145 HD Recording & 6ms FPV Latency
-Single board Supporting Start/Stop Recording via UART Control
-HD Recording supports QR Code Setup Analog FPV supports Firmware Update
Package:
1x RunCam hybrid Camera
1x Plastic cover
1x 3PIN FPV silicone cable(male)
1x 3PIN FPV silicone cable(female)
1x Set of M2 screws
Oct 10, 2019, 01:36 AM
Merch's Avatar
RunCam Hybrid // Dual Cams Single Board (10 min 17 sec)
Mini-Review Caddx Tarsier review - 4K 30fps 1200TVL Dual Lens Super WDR HD DVR Mini FPV Camera Bill M - RC FPV Equipment 7 Aug 20, 2019 01:34 PM
New Product Foxeer Mix 2 1080P 60fps DVR HD Recording Mini FPV Camera Low Latency FOV 155 Degree Merch Banggood.com 0 Jul 02, 2019 06:09 AM
New Product Caddx Tarsier 4K 30fps 1200TVL Dual Lens Super WDR WiFi Mini FPV Camera HD Recording alex_nikiforov Banggood.com 3 Jun 11, 2019 01:26 PM
New Product RunCam Split 2S FOV 170 Degree Super WDR Mini FPV Camera 1080P 60fps DVR HD Recording scousethief Banggood.com 10 Jan 08, 2019 05:54 AM
