Sep 16, 2019, 05:39 PM
New Utter Kaos
I took my new Utter Kaos out for test flights today and shared a few pics. Had a problem with the OS AX 65. Iíve had 3 of of these engines but this one seemed really tight. I though when I got some fuel in it , it would be OK. No , turning it over it squeaks really loud. I tried to fire it up but it didnít seem right. Any ideas or just sent it back to Tower?
Sep 16, 2019, 06:08 PM
I heard the ax engines had a cylinder plating issue. I would be getting it checked out
Sep 16, 2019, 07:42 PM
CPA #100
flyonenow's Avatar
+1 on checking the cylinder.
If all looks good. I would pre heat with a heat gun until it turns over freely, then fire it up and follow a normal break in procedure.
Paul
Sep 17, 2019, 05:12 AM
A man with too many toys
Those nickle plated cylinders are notorious for causing problems (ABN). I would gladly pay a little more to have a chrome plated cylinder.
Sep 18, 2019, 04:04 PM
I would not use a starter, pre heat and flip it...Just my 0.0002 worth....
Sep 18, 2019, 05:55 PM
I tried flipping it. It would pop but it was so tight it squeaks. Got tired of flipping.
Sep 18, 2019, 09:09 PM
AMA 46133
SeismicCWave's Avatar
That is a bit unusual. Is the engine under warranty? If it is send it back. If you cannot send it back then do the following.
Take the engine out. Take off the glow plug. Put some castor oil down the glow plug hole. Heat the cylinder area up with a head gun. Flip the prop at least 100 times by hand. Make sure you have lots of oil. If the engine squeaks it is not a good sign. I would also open up the cylinder head and check the piston and sleeve first to see if there is anything unusual. Just sure you use castor oil when you are moving the piston up and down.
Sep 18, 2019, 09:21 PM
Iíve got another new engine that feels much better. This should be under warranty, Iíll just send this back. Hope Tower takes care of it. Thanks
Sep 18, 2019, 10:16 PM
AMA 46133
Much better. Their manufacturing tolerance must have been off.
Discussion Kaos Kaos which Kaos? b25p51 Fuel Plane Talk 19 Jan 12, 2019 05:24 PM
Question Utter Kaos, GC and plans? SkySergio09 Classic Pattern Flying 2 Jun 19, 2016 10:20 PM
Yippee! My new classic build. Killer kaos 60. walter3rd Classic Pattern Flying 33 Feb 05, 2016 11:30 AM
Question Bridi Utter Kaos bent-prop Classic Pattern Flying 3 Jul 03, 2014 12:45 PM
Discussion Classic Pattern Aircraft Bridi Utter Kaos 60, LPU jetflyr Classic Pattern Flying 0 Aug 21, 2012 12:31 PM
