Sep 16, 2019, 05:22 PM
N99JH's Avatar
Help!
Axi 5360/20
I have recently bought this motor for use in a WWI giant scale model.
According to AXI data this motor should be run with a 30-20 propeller on 10S Lipo. The weird thing is that they say that max. current capacity is 65 Amp for 20 Seconds!!!
When I run Ecalc with the motor data - there's NO WAY this motor will EVER fly anything without burning to ashes within seconds!
Yet, I know that back in 2015 Dave Perron flew a Glenn Torrance Fokerr D. VIII weighing about 30 Lbs. with this motor and the recommended 30-20 prop on 12S, 5,000 mAh pack, so - what gives?
10S pack is nominally 37 Volts so, if Watts = Volts X Amps, than: 37 X 65 = 2,405 Watts.
When I run Ecalc with a model that weighs 30 Lbs, on 10S, 5,000mAh, and, 30-20 prop I get power required of 1,370W to turn that prop 3,500 RPM but the current draw is 108A and the temperature 180F.
I don't know what to think.
Any help offered to shed light on this matter is greatly appreciate.
Sep 17, 2019, 03:03 PM
Originally Posted by N99JH
. . . . When I run Ecalc with a model that weighs 30 Lbs, on 10S, 5,000mAh, and, 30-20 prop I get power required of 1,370W to turn that prop 3,500 RPM but the current draw is 108A and the temperature 180F.
10S (i.e. 42v fully charged) only needs 32.6A to develop 1,370 watts; 108 amps would give 4,500 watts (assuming no voltage sag)
Are you sure eCalc doesn't think you've specified 10 Nixx cells instead of 10 LiPo cells?
Sep 17, 2019, 04:16 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
... I don't know what to think. ...
If user abenn above did not hit the nail on the head, can you post the eCalc screendumps?
Vriendeljjke groeten Ron
• Without a watt-meter you are in the dark ... until something starts to glow •
e-flight calculatorswatt-metersdiy motor tips&tricksCumulus MFC
Sep 17, 2019, 04:52 PM
N99JH's Avatar
Sorry, I inserted a wrong value. The 1,370 Watts is the value for "Motor @ Optimum Efficiency" which indeed correlates to 32.6A. Under full power Ecalc predicted 4,207W and 108A.
Sep 17, 2019, 05:07 PM
N99JH's Avatar
Ron
No, he did not hit the nail on the head. Please see my reply to him.
Attached is a screen shot of the Ecalc calculation with my airplane information. By the way, Model Motors list the current V2 version AXI 5360/115 with the same Max. current of 65A for 20 seconds. !!???
News AXI 5345 and 5360 Brushless Motors with Telemetry Jason Cole Power Systems 0 Oct 12, 2017 09:44 AM
Question AXI 2808/20 or AXI 2217/16 ? flashprash65 Power Systems 1 Jul 20, 2007 01:43 AM
Discussion Axi 5360 BandDButton Power Systems 0 Oct 25, 2006 06:39 AM
AXI 2808-20 vs AXI 2808-24 for Quiet Storm sportytourer Power Systems 15 Sep 23, 2005 05:11 PM
Which AXI for Pitts? AXI 2808/20 or 2808/24? cadconversions Power Systems 8 Apr 17, 2004 04:05 PM
