This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Sep 15, 2019, 11:47 PM
Mini-HowTo
EC1500 and Esprit Prop Shaft Adapter 5 mm x M8
The Esprit Prop Shaft Adapter is about 30 % bigger than the stock unit so you can put more torque on the nut and threads. This translates so about 30% more gripping power between the aluminum collet and steel 5 mm motor shaft. In Jason Ms video he recommends holding the spinner backplate or motor to keep the threaded adaptor from turning. This is done with one hand while the other hand uses a wrench to tighten the nut.
I made up a tool that slips into one of the 4 motor cooling slots and this keeps the motor/shaft from turning while the collet is being tightened onto the shaft. Its a steel 6 mending bar that I cut with a hacksaw and filed down to fit the slot. Its bent into an S shape to fit between the prop and plastic nacelle. The nacelle is cut out for clearance.
Question Where can I find edf shaft adapters for 2 and 2.3 mm shafts? gtinbm Electric Ducted Fan Jet Talk 4 Feb 10, 2016 04:22 PM
Question Who sells 3 mm X 6 mm prop adapters for 3 blade GWS? cyclops2 Electric Plane Talk 5 Dec 13, 2010 10:42 AM
Question Prop adaptor for a 3x2 prop on a 12x30mm medusa 4000kv with a 1.5 mm shaft TheDonski Power Systems 4 Jun 05, 2008 10:12 PM
3mm prop adapter on a 2.3 mm shaft? Martin Hunter Electric Plane Talk 6 May 23, 2005 01:35 AM
AC prop adapters for 3.0 mm and 3.2 mm shafts Dr Kiwi Power Systems 10 Apr 03, 2004 02:02 AM
