Sep 15, 2019, 10:47 PM
GeoffS's Avatar
Mini-HowTo
Servo "breakout board"
I use a the FlySky X6B receiver quite a lot. It's reasonably small and light, and it has six PWM channels that makes it handy for simple fixed-wing planes.
One downside of the size is that the PWM signals come out on a nine-pin JST-SH 1.0 connector.
Some flight-controllers have a similar configuration using a connector and/or solder-pads for PWM outputs.
To help connect my receivers to conventional 3-pin servo connectors, I made a small PCB that you can solder up to seven 3-pin headers.
The + and - pins are all connected in parallel, and there is a separate solder-pad for each signal wire.
I also designed a tiny cover for the pins on the back.
The full information is on Thingiverse at: https://www.thingiverse.com/thing:3646907
Data Breakout board on HP PSU DPS-800GB / HSTNS-PD05 gurkburk76 Batteries and Chargers 0 Jan 30, 2018 12:07 PM
Discussion RMRC BLHeli Breakout Board Waterbound Mini Multirotor Drones 0 Nov 04, 2015 07:33 PM
Discussion Good servo breakout board Zoxks Power Systems 3 Sep 13, 2015 12:05 AM
