Sep 15, 2019, 02:02 AM
FrSky Taranis Q x7 - telemetry RxBt = 3.1 V ?
Hello everyone.
Can someone explain me why RxBt is showing me this value? ''3.1V''
I have a Taranis Q x7 with a X8R receiver.
I just want a warning when the battery (Lipo 7.4V 1300Mah 20C) is at 6.2 - 6.4 Volt.
Or that each/a cell is below 3.2 V.
But when I tested this battery with my LiPo checker it showed me that it had 3.69 V and 3.66 V left in his cells. But my taranis is showing me RxBt = 3.1 V
What can I do? Is something wrong with the receiver or am I missing a setting?
EDIT 15 september 19' :
After a lot of searching I found some kind of solution in the manual of OpenTX.
''Ratio
The multiplier to use to get the correct reading; Usually in volts. Using a multimeter measure the voltage. If the multimeter voltage and sensor voltage do no match adjust the ratio until they match.''
It seems that inside the editing mode of the sensor RxBt, there is a option called ''Ratio''. this is where you need to adjust the amount of Voltages read and the actual Voltages measured by a LiPo checker of Multimeter.
But 5 min later, the sensor read 7.9 V, but when I checked it with my Lipo tool I still had 4.10 V in each cell = 8.2 V.
So I again adjusted the ratio.
So a 2 cell battery needs the ratio at 22.0. Atleast for me.
Greetings
Sep 17, 2019, 08:41 AM
Happy FPV flyer
Kilrah's Avatar
RxBt gives you the supply voltage to the receiver. That will always be 5V in a typical electric setup since it's regulated by your BEC.
You cannot get your battery voltage without an external sensor.
Sep 17, 2019, 09:06 AM
Carbo (-nator) ;-)
Do you supply your RX with 2s directly? With the default ratio (13.2) for RxBt your radio should show you the correct supply voltage. If it shows 3.1V, something is wrong. Connector/cable or A/D converter (unlikely).
Sep 17, 2019, 02:21 PM
I just figured it out. Thanks for replying!
I found a simular forumpost somewhere else.
You're probably using a BEC which gives a constant 5V to your receiver, so you can't use RxBt to read your battery voltage, you need an extra sensor.
Also it seems you might be confused, RxBt is the supply voltage of the receiver, but what you say suggests you're trying to look at it to see the radio's battery voltage.
I just ordered mini voltage sensor from HK, hopefully they come with the cable I need. Smartport -> Sensor
And yes after setting the ratio back to 13.2 it was back at 4.99 V - 5.00 V.
Again thanks for replying, I didn't got any answer from other forums. New to the hobby, so maybe it's a stupid question?
Sep 18, 2019, 01:43 AM
Verwijder de sensor en laat OpenTX hem opnieuw vinden. Voor RxBat moet je nooit aan de ratio komen, deze is VAST. Als de waarde niet klopt standaard is de ontvanger kapot.
New Product NEW Radio - Frsky Taranis Q X7 - what do we know so far? sevet Radios 2778 Apr 27, 2019 02:11 AM
Discussion FrSky Q X7 Telemetry aerokiwi Radios 0 May 15, 2018 04:50 PM
New Product FrSky Taranis Q X7S M7 Gimbal Transmitter - Upgraded Q X7 & M7 Gimbals D Gains Radios 14 Nov 01, 2017 02:12 PM
Discussion taranis Q x7 reading Apm 2.6 telemetry colindo1 Scratchbuilt Multirotor Drones 0 Apr 18, 2017 01:49 PM
