Sep 14, 2019, 11:03 PM
CrazyKB's Avatar
Turning
Hello all.
I've been practicing on RF8 for about six to seven months, coming off of coax and quads. I'm quite good a sport flying (full rates no expo). However, there is one aspect of flying that still gets me in trouble (crashing): pitch of the nose. When I fly with the nose straight, I can make coordinated turns quite well. However, during faster forward flight, with the nose pitched down, I've noticed that the heli is more prone to losing altitude while turning. Is it best to level the nose before a turn? I've noticed that most (real) helicopters don't fly with the nose pitched down, at least not that much.
Thanks.
Sep 15, 2019, 01:31 AM
When heli tilts forward (nose down) in fast flight you need to also add throttle to compensate the lift generated by rotor. More tilt during flight, more throttle to keep the attitude.
Sent from my iPhone using Tapatalk
Sep 15, 2019, 10:49 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
No simple answer, as pointed out above, whan you pitch the nose down to fly fast forward you have to add more collective. In a banked fast turn you have to balance the bank angle, elevator, rudder and collective to achieve the desired radius of turn and maintain height.. It's a balance of all control inputs.
Generally if you are loosing height then you probably need to reduce bank angle and/or increase collective.
Flying helis since 1978
rotorist's Avatar
Add throttle for fixed pitch helicopters, add collective for collective pitch helicopters.
Pull slight rear elevator at the same time as you do not want to speed up the helicopter.
(unless you want to increase forward speed.)
rotorist.
Sep 15, 2019, 08:30 PM
Turning
My bad. it should be more collective pitch (if the head speed is constant in IU1/IU2) to keep the attitude in forward flight.
(As itís the same left stick to control that movement...)
Sep 15, 2019, 11:14 PM
Suckerpunch's Avatar
Sep 20, 2019, 08:42 PM
CrazyKB's Avatar
Thanks for the replies.
Discussion clock wise turns vs. counter clock turns Batty33res Electric Heli Talk 25 Mar 12, 2017 10:09 AM
Question 5.8 Spironet Antenna RH turn or LH turn winginman FPV Equipment 2 Jun 11, 2016 05:47 PM
Idea Quads suck at turning, so why do we turn? maliqua Scratchbuilt Multirotor Drones 18 Apr 16, 2016 01:31 PM
Discussion Thinking about slipping turns, skidding turns, flat spins aeronaut999 Modeling Science 1 Mar 01, 2016 09:13 AM
Discussion Turning technique! Bank and yank vs roll turn. Swab FPV Racing 5 Dec 22, 2015 10:36 AM
