This thread is privately moderated by Kmot, who may elect to delete unwanted replies.
Sep 14, 2019, 11:01 PM
Grumpa Tom
Kmot's Avatar
Converting a PC PSU to a 12V DC bench top power supply.
Today, I converted a Hewlett Packard 500W PSU to a 12V DC bench top power supply to use with RC battery chargers. I cut off 53 wires and 10 connectors. I grouped like wires together and then covered them with heat shrink tubing. I soldered 6 12V leads and 6 ground leads each in parallel. I soldered the power on signal wires together so that the power supply turns on when plugged into 120V AC. When I was finished I connected my Turnigy quad charger to the converted PSU and the charger lit up and then I charged a 2200 3S LiPo at 8.36 amps. Pretty cool.
Sep 16, 2019, 12:08 PM
Waste Nothing
RickC_RCAV8R's Avatar
@Kmot :
If I remeber right , there is a single purple wire in this PSU that is the ENABLE for the whole output . Can't recall if it has to be grounded or connected to +5 to activate .
Sep 16, 2019, 03:32 PM
Grumpa Tom
Kmot's Avatar
Yes, there is a single purple wire in the 24 pin connector. None of the videos I watched on Youtube referenced that wire so I did not do anything with it. But thanks for the heads up.
Converting PC power supply to power 12v charger? steve crewdog Batteries and Chargers 92 Jun 29, 2018 01:09 PM
Discussion PSU Thermaltake Toughpower convert to power supply HonzaJaros Batteries and Chargers 0 Sep 13, 2015 08:53 AM
Discussion converting a pc power supply with dual 12v rails? SlyKYFox DIY Electronics 2 Oct 27, 2012 09:39 AM
Question PC PSU Bench supply question MiG-3 Reno Rocket Batteries and Chargers 3 Aug 30, 2012 08:00 PM
Converting pc power supply to charger AC-DC converter.....? foss1997 Power Systems 9 Mar 25, 2002 08:21 PM
